Evap box
r.booser
Knoxville
Ron
So I have slowly been fixing up my 85 c20. After getting it running smoothly I notice the heat isn't blowing out the vents very strong. Well my evap box (ac truck) is broke on the bottom and allowing most the my air to escape. I'm not worried about having ac so if I eliminate it I wouldn't be upset. Problem is I can't find anything to fix this online. Do you guys know were I can either get a new one or a ac delete kit but still have heat?
How bad is it broke? It's just plastic right? Find a piece of plastic, plexiglass, tin, even if it's a beer can, and duct tape it over the crack or break. Sounds redneck, BUT, that's really what DUCT tape is for, taping and sealing Air Ducts. It's resitant to heat, cool and moisture.
If chaning boxes, may as well go with another AC box unless you plan on changing all he stuff on the front of the firewall too and then you'd have to redrill hose openings and all that. Prolly eaiser just to replace the whole air exchanger and go back with the AC unit that's currently in it. JMO.
r.booser
Knoxville
Ron
its a decent amount and I don't think a beer can will cover it. It seems to be a plastic/fiberglass mix. If I can purchase a ac delete or new box that would be best. But I've used my fair share of duct tape and could probably get by for a while...haha
Duct tape falls in that category with fat chicks and mopeds. It'll work ok but don't let your friends see it.
r.booser
Knoxville
Ron
haha exactly, hell I'd ride a moped!
As high as gas prices are, I will too, but I'll damn sure have a full helment and dark tinted goggles on. Still can't do the fat girl though. I did try once but nooo, had to back out on that deal.
The repair will probably be easier to make if you remove the inboard cover (and the evap coil along with it):
twzorek
