Edlebrock carbs and fuel pressure regulators
84-C20
Chevrolet
I've got a 1984 Chevrolet C-20 that the former owner installed a edlebrock carburetor on. I believe that I'm having some minor issues with it because of excessive fuel pressure. I'd like to install a pressure regulator, and I'd like to hear from folks that have one, what they installed, and what they like or dislike about it.
Dutch Rutter
Independence, Or
Joshua
Heres my setup.
Regulator
https://www.summitracing.com/parts/hly-12-840
Gauge
https://www.summitracing.com/parts/aei-15632
Line and filter from the regulator to the carb 1405
https://www.summitracing.com/parts/edl-81343
Line from pump to reg
https://www.summitracing.com/parts/edl-81233
Then I ended up using lots of different AN fittings and adapters. I blocked the fuel return line from the regulator itself as my fuel pump as a return line. If your does not you'll want to run one from either the pump or the regulator. It's always best to keep the regulator close to the carb to avoid the pressure bleeding down over distance and bends. It's also best to have the regulator hard mounted. Mine is not currently but between the hard line I have it secure enough not to create leaks. It works well but could be better by being hard mounted. Which it has the provisions to be done I just haven't yet. It also wasent a whole lot of money.
Camar068
Air Force Supporting Member
10 yrs Air Force
84-C20
Chevrolet
David, thanks for the link I read it over. Joshua thanks for the pics of your set up and all the info. I haven't had a chance to do anything yet, but I will one of these days.
thirstybob
Colorado
Robert
C20 Custom Deluxe
I bought the Edelbrock fuel pump which states it is set at 6 psi. I tried a regulator and could not get it set correctly, plus it was a pain in the ass to mount it in the right spot. My fuel pressure gauge doesn't go over 6 psi.
Camar068
10 yrs Air Force
fender well works good. thats where I had mine. One thing that bothered me was the guage bounced so much it was hard to tell where to set it at. Say you wanted 5 psi, so do you set the max to 5 or the minimum.....or average with mechanical fuel pump?
84-C20
Chevrolet
It bounces like that because a mechanical pumps produce pressure like that. I would say set for max.
78C10BigTen
pennsylvannia
C10 BIG TEN
Heres my setup.
Regulator
Gauge
I like your valve covers!
potent rodent
indiana
butch
86 and 78
350 and 305
why are u running ported vacume ?
84-C20
Chevrolet
I'm not sure who you are asking this question of but for me I'm running ported because that was factory on my truck and my emissions devices, primarily cat, air pump are intact. Plus I find I have a better cold idle on ported.
78C10BigTen
pennsylvannia
C10 BIG TEN
Looking at the carb from the front, left is ported correct?? If so i am also running ported.
84-C20
Chevrolet
bajadiver
