Driver4r's Monte
Driver4r
Nebraska
Trevor
k10,c20
These are all pics ive had or just taken of the engine that never got posted.
350runner
tx
Ceasar
Nice red bro
Moderator Administrator
So did you get the heads machined to handle the higher lift cam or are you just going to coil bind the springs until they break?
Driver4r
Nebraska
Trevor
k10,c20
more
Driver4r
Nebraska
Trevor
k10,c20
right now they will clear around .580-.6 lift, Its my spring thats the problem, i need a lower bind height, right now they are 1.17, and i need 1.1. But the retainers dont contact the guides.
And yes i still have to get different spring, but its easy to change them on the engine.
You sure about that? I'm pretty certain the spring seats need to be milled down for anything over about .480. And if you're using a 1:6 rocker, even less than that.
Driver4r
Nebraska
Trevor
k10,c20
350runner
tx
Ceasar
Sweet!
Driver4r
Nebraska
Trevor
k10,c20
As i just said, right now they will clear around .580-.600. I never said they wernt modified, i just said that right now they WILL clear.
Yes, they have been worked.
And im using the 1.5 rockers right now, debating about getting 1.6's for the intake since they will clear.
And the problem with vortecs are the retainer to guide clearence, most are factory at .460-.480, but with a little work to the guides you can acheive more lift. I also had to open up my pockets cause my springs have dampeners compared to the single spring factory springs.
Driver4r
Nebraska
Trevor
k10,c20
more
Driver4r
Nebraska
Trevor
k10,c20
And now your caught up.
Driver4r
Nebraska
Trevor
k10,c20
today i Picked these up.
When i got home i buttoned up the timing cover section, and put the water pump on.
Now whats left is,
Put balencer on
intake(being delivered)
oil pan gasket
valve springs
Marine Corps Moderator
Did you go with a stock timing cover? or a aluminum? You not going to paint the valley?
Driver4r
Nebraska
Trevor
k10,c20
Yea, on a tight budget i reused the stock cover, and im leaving the lifter valley bare.
NateP350
