Drinking coolant
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
is it normal for this type of truck to drink coolant? it filled it to min. about a week ago and have driven it twice since that time but it is almost empty again? thank you for all your help.
74 Shortbed
Shouldn't lose coolant at all, you have a major leak somewhere should be able to see it unless it's internal, best to do a pressure test you can rent a tester at a parts store if you don't already have one.
CRM
Pasco, Washington
Casey
K2500
350 CI
You don't have a leaking heater core by any chance? It's fairly common for them to leak in these trucks.
Camar068
10 yrs Air Force
check your oil for drops of coolant on the stick. Anything but oil on the stick is bad.
Iowan
Iowa
Calvin
K1500
350 crate
Well thank the Lord theirs no coolant in the oil. And the heater core was replaced before we bought it (week since we bought it). Could I use a air compressor instead?
87ChevyR10
Kansas
NA
NA
NA
What color is your exhaust? White would indicate coolant being burned. Even if it's not producing white smoke, stick your hand in the exhaust and smell it. IF it smells sweet, it's coolant.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I promise it'd be easier to pressurize the cooling system with a pressure tester. You can borrow them for no charge at an auto parts store.
Iowan
Iowa
Calvin
K1500
350 crate
ok ill barrow one. the exhaust is not sweet. I think it might just have to get another coolant tank.
Iowan
Iowa
Calvin
K1500
350 crate
Thanks so much.
74 Shortbed
Let us know what you find out.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Also depends on how hot tour truck runs and what the weather is like. Mine will tend to evaporate a fair amount of water from the overflow when running a lot of errands during a hotter week.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Do you think it's just because of heat, or would the low relative humidity also be in play?
Iowan
Iowa
Calvin
K1500
350 crate
I didn't think about that the truck always runs cool and it's been a little hotter these couple past weeks. But I'll still will find out what else might be wrong and I filled it almost to min.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Low humidity will allow the water to evaporate easier, the higher temperature will just speed up the process.
If you really wanted to get into specifics, you could also check the atmospheric pressure changes too... Lower pressure = lower boiling point. But that doesn't ever change enough to really make a difference.
twitch1989
