Drag limited
1lejohn
texas
john
k-1500, 2500 HD
What are your thoughts on my truck being drag limited at a little above 3K rpm's in third gear at 85+ MPH. turbo 350 and 3:08's with 32" tires. Mild 350 build. It pulls hard right to 3k and then just stops. I think it might be. Not really worried about going any faster just curious.
Chevy 88
Canada
f7t6
GMC
Perhaps there is a fuel shortage or something going on with the weights inside the distributor.
If you back off the throttle for a few seconds and then get back on it does accelerate better,briefly?
Sad Sack
Nebraska
Goober
C15
Just curious, has timing been checked?
cadillac_al
Maine
Alan
Most square bodies with 3:08's easily rev past 3k in 3rd gear. I'd say it is leaning out for whatever reason. When mine lost the fuel pump lobe it wouldn't rev but I can't remember where it was topping out. My fuel pressure was 1 1/2 psi though.
1lejohn
texas
john
k-1500, 2500 HD
The timing was off by a bunch. When I replaced the front cover for the roller cam, I attached a timing tab that sits to the driver’s side of the H2O pump. The stock one was I’m guessing the sight tube behind the H2O pump.
I marked the balancer to the new timing tab position. By setting the engine to TDC on the #1 cylinder. I found that my initial timing was retarded by a lot. The vacuum advance had 20 degrees. The engine was running with slightly retarded timing or very little advance.
At higher engine speeds and low vacuum, I didn't have enough total timing, thus the surging problem. The engine was fighting against self.
I set the initial to 12 degrees advanced and checked the mechanical advance I had 36 total degrees with the vacuum advance disconnected. I connected the vacuum adv and took it for a spin. I was getting some pinging when transitioning from vacuum advance to strictly mechanical. I tried to adjust the vacuum can for less timing. It's stuck at 20 degrees. 56 degrees wasn't going to cut it.
I had to take some of the initial timing out to keep it from pinging. I'm at 26 degrees with vacuum advance connected. I'll order a new can and put this to rest. The engine does pull past 3K rpm now. In 3rd gear i got it up past 4k. I am guessing the Mph is close to 100.
Jeremy89
