- Apr 11, 2017
- kansas
- Rick
- c20
The aftermarket ones usually limit centrifugal to 18degrees that comes in quicker so now you have to bump initial to get the same total.And yes that's going to be quicker off the light, and probably just fine for something that does not see much heavy work. I wouldn't recommend it on a 305 with ESC becausev they need a lazier curve the are ping monsters. They upped the compression which is why they went to ESC .
And yes they also changed the vacuum advance amount so they could run retarded at idle for better emissions.
