Delay Wiper Module
87chevy_com
Clint
L83
first post here, (i see this thread is a year old too)
I am usually on 67-72truckforums. I too have been wanting pulse wipers to work on my 1987 (factory pulse optioned truck) for years. I don't drive it much in the rain, but when I do, delay is quite nice... it quit working years ago. I came across detroit muscle wiper module solution, and found that they use a modern wiper motor, 2015 corvette, their harness, their module and their adapter bracket ... I want ready to spend that much, being that I am extremely crafty when it comes to fabrication and wiring.
There's several things I don't like about their solution:
its not for 84+ with column wiper switch
doesn't use factory wiring which requires an additional hole in the firewall
Anyway, I decided to buy a wiper motor from rockauto. Found the part number for the wiper motor conector and gm wants over 100$ for a pigtail lol... did some research, got the connector, terminals and seals for around 20$... Prefer no mumbo jumbo splices when its not necessary... anyway.. bought an ArduinoUno years ago to play with, barly now how to use it, so learned a lot and got myself a working wiper delay program.
Once I got the program to work, I bought a GMT400 style wiper switch, looks identical to the stock c-10 but only has 3 wires and has the modern detents between the 5 delay speeds (which is why I bought it in the first place. Did more debugging, more programming and got it to work with the corvette wiper motor... (wired like OEM)
Now that I had 2 working programs, with both switch's, I figured why not use the factory wiper motor? And then made the "relay harness" work with the factory wiper!
And then learned how to use another program, Eagle so I can make a PCB... about 2 weeks later, 2nd version:
designed so the module goes off to one side under dash, the relay module goes off to the other side, and the connections are OE on the column with no bulk...
video link hosted on my website:
gmt400 Switch, c-10 wiper motor test
link my thread on the project on the other forum :)
Moderator
Wow, you're telling me that there's people who LIKE the detents in the delay speeds? Lol. Personally, I don't care for them at all. Guess I'm a weirdo.
Raider L
Shreveport, LA
William
The factory maintenance book indicates the reset circuit is in the wiper motor. So if your wipers won't go all the way down when you turn them off it's in the wiper motor circuitry inside. I have the same problem when I turn mine off. And like a dummy I get ready to turn the wipers off and then try to time it so that when they get all the way down I'll try and catch it the second before they start back up the windshield again. It might take two or three times before I get it right. Then sometimes, after I give up trying to time it just right I say "screw it" and leave them just above being all the way down, I'll be driving along and they will suddenly go all the way down and stay. It's crazy.
I've wanted to put a delay in my truck for many years but I'll need to rebuild the wiper motor as well, after all mine is the factory original wiper motor. And that just seems to much trouble right now. They are working. It would be different if they weren't. I might be motivated to put the whole nine yards in if there was a real problem.
grummy
Midwest
C1500
With every car/truck I have ever had, I kind of disliked the delay. Especially the ones that make another swipe when turned off. And, I was always adjusting it... never right.... So, on my truck, I simply have a N.O. momentary push button in a small housing right under the turn signal switch. When I WANT a wipe, I just push the button.
All I had to do is momentarily ground the low speed wire to accomplish a single swipe (connection "C" / Grey wire on my switch), and the wiper automatically goes to park when done.
My truck doesn't have the module, but if I want an adjustable delay, all I'd have to do is use a timer relay to ground that same gray wire.
SquareRoot
Schematic please.
grummy
Midwest
C1500
I'm new here. Haven't even looked into how to post photos !
But if I have it correct, all squarebodies wiper switches supply a ground to the motor for the speed you want it to run. Check your wiring diagram. My motor has 3 plugs on it. Way top is the Park Terminals, next lower is Washer activation, and the bottom is for motor. Mine has 3 wires on this bottom plug. One is hot when the key is on the other 2, stand in wait for a ground from the switch to make the motor run.
So, take a jumper wire from any ground and touch it to one of the the Non 12v wires on that bottom plug for a second then remove it. The wiper should wipe once and go back to park. Choosing one or the other non 12v wire will select which speed you want it to wipe at.
Find that same wire at the switch (mine is terminal "C" - Gray), tap into it and ground it when key is on. Should wipe and park in the same fashion.
So, you just put a momentary switch between that wire and a good ground. You don't even have to fuse it because the whole circuit is fused via the 12v feed.
I'll find time this winter to post images and such. Just too busy getting my truck wrapped up before snow. It's gonna be a daily driver, so she's already juiced up with fluid film.
mjsnarr
Arkansas
Michael
Anyone know what piece of this board controls the delay and home functions. Wiper fluid and low and high work.
dudleyrushmore
