Deadening Actual Fenders, Bed Panels, Doors and such????
smullen
Fredericktown, Mo
Scott
I6
Anyone ever put deadener (Spray or Applied Mat, Roll or cut piece) on anything aside from the cab and under the door panels ?
My new bedsides are due to show up between Friday.
It'll probably be a few weeks before I can get them on.
I was wondering if anyone had deadened panels like these with Spray or mat???
I love the sound of a panel that has a sold Thunk or Thud as compared to the tinny, coffee can sound when you rap your knuckles or something on a fender, door or whatever....
Moderator
Just a few large squares of mat applied to the bedsides will make a big difference. No need for fancy sprays, imho.
Your panels will have the sound of quality and refinement. But some people may think your panels are full of bondo, lol.
Ford installer a metal thing on the back of the cab in the center that, frankly, I dont know what it does, but Im told its a NVH thing. maybe it could be swapped as well to aid the mission you have.
"It's a harmonic dampener used to deaden vibrations in the cab by absorbing them"
Moderator
Manufacturers have done that here and there. Usually some type of weight mounted with an isolator or two. I'm not sure how much they actually do, especially the ones mounted to subframes, which in turn mount to the body with rubber mounts.
I looked it up a bit more, I dont think it would do much on a square since the rear panel is thicker than ford. The ford is tinny and you can tell its less compared to a square bodies solid panel. so I suppose it vibrated lol
Bennyt
Surprise
Ben
The bedsides are exposed from underneath so I would avoid mat that can trap moisture and dirt. I've seen people apply raptor liner or comparable. I don't think there would be a sound difference in the cab though.
I Line'xd some of the underside of my K5, along with the interior and would spray wd40 on it before offloading so mud would be easier to wash off. Not sure it made much of a difference with mud but sealed the interior nicely.
The aftermarket bedsides are thinner gauge and it might help when prepping for paint if they didn't resonate. On my Nova, the bodyshop applied dynamat on the underside of my roof as they said the roof was vibrating along with the air sanders and progress was slow and loud.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I haven't used any but there are some spray on sound dampening products that seem to get good reviews, I agree with @Bennyt that stick on mats could trap moisture. Most of the stick on butyl rubber sound insulation mats say not to install where they are exposed to moisture for that reason.
Lizard skin seems to be popular but a company called second skin audio seems to be less advertised but appears to have good product. Second skin has a spray on & one they refer to as "sludge" its a 2K that gets put down with a trowel or putty knife.
The sludge product seems like it would be good on the inside of bed panels and fenders.
Bennyt
Surprise
Ben
Applying to bedsides, fenders, etc won't do anything for noise in cab. So other than making it sound more solid and possibly helping when bodyworking, I think it's probably wasted other than some chip/corrosion protection.
That being said. I used lizard skin on my son's truck and plan to use it on 2 more vehicles soon but it is expensive at $600-800 a vehicle.
Finkaire
Finkaire
California
Loren
Silverado c10
This worked perfectly on my truck inside the doors and anywhere on the interior I could get to, huge difference. And the price is right!
I used Raptor Liner under the cab and up the firewall when I did the drivetrain swap. When I pull the bed to clean/re-seam seal and bed line the bottom side I plan to spray more of the Raptor up as far into the bedsides as I can just to cut down on the tinny-ness of them
smullen
Fredericktown, Mo
Scott
I6
Thats exactly my thought. I don't know why, I just want the whole truck as deadened as possible.
I hate the tinny-ness of a knuckle wrap on the fender, shutting of a door, hood or tailgate. I want a thud, not a ring. Just my preference.
Agreed. Plus it'll just help with the harmonics/vibrations in general. My truck has a cammed 5.3 and pretty loud exhaust, so I get alot of resonance/noise coming from the bed going down the road/cruising on throttle
smullen
Fredericktown, Mo
Scott
I6
Check this out on Amazon...it comes in different thicknesses. I bought one small box to test first for $38.00 in 50mil. The stuff is way dense and is amazing.
I may try a bunch of that for the cab floor and back wall, but I think inside the bedwalls and underside, panels really exposed to the weather, ill spray them.
Kurnacopia
Tucson, AZ
Scottsdale
Agreed...you dont want to expose this to weather because its applied with a sticky backing. Inside though....its outstanding. Rhino lining is what I use.
Best of luck!!
jwtlake
