Dang truck.. one thing leads to another..
Konas new ride
Alberta
Gerald
fixing speedo.. while under there... Notice there is a line on the fuel valve dripping. There are four lines on one side then two on the other side all attached. Then there is one kinda off to the side, what should it be tied into?
TIA
Moderator
Can you get a picture?
Konas new ride
Alberta
Gerald
Its the shiny black that is dripping fuel.. If i could get this to stop i would be happy..
Moderator
Looks like a drain tube? I don't remember my valve having that tube. I'd guess it's starting to leak internally though. Does the valve still work?
Konas new ride
Alberta
Gerald
Never tried it.. My cousin said the passenger side tank leaks.. i assume its this valve and he just never looked under the truck..
Moderator Administrator
Does 81 have canister purge emissions device? That might just be a vent for both tanks. :shrug:
Konas new ride
Alberta
Gerald
Its a 80.. i cant find the spot to change it from saying 81 in the side list under my name.. :console:
Im not sure about the purge device....:argue:
If you had the purge canister, it would be behind the left headlight in the engine compartment in the far front left corner.
Took care of the year model under your user info too. :adminpower:
Konas new ride
Alberta
Gerald
Thanks.. I will take a look for the canister once my boy lays down for his morning nap..
Thanks for the change also..
Heading to town today to get transmission oil so i can change the pan gasket as its seeping. i also picked up a gasket set for the oil pan for the motor.. its seeping also.. I also need to change out the valv cover gaskets..
Konas new ride
Alberta
Gerald
By this i assume your saying i should change the valve out.. I think i'm going to do that.. just to be sure..
My wife is going to wonder if i will ever stop spending money on this thing.. :argue::drunk::argue::word::boxing::sad72: :suicide:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Tell her no. A real man's truck always needs tinkering. Even when it's "done" there is money left to be spent.
Sure there is. Always got enough left over for beer !!!
Moderator
It must work then. If you have it switched to the driver's tank, that means that valve is engaging every time you turn on the ignition. Unless someone has rearranged the hoses of course. Just have a helper run the ignition and operate the switch while you feel/listen for it to work. If it works, I'd try capping that tube just to see what happens... and probably locate a new valve and have it ready to swap in at some point.
The little lines are the tank vent lines or return lines of some sort. They go to the fuel pump on mine IIRC.
Konas new ride
Alberta
Gerald
fuel for the Harley.. beer and snacks.. Wait.. that was before the boy came along...
Konas new ride
Alberta
Gerald
Im trying to find one but getting one that i dont have to change lines or reworking the wiring is seeming to be difficult..:argue:
Gurn
