cruise disconnect switch hose routing?
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
where is the hose and wires supposed to run? mine were just hanging and it doesn't seem right. the last switch was broke in half, don't want to break the new one!
ps, really hoping this will fix my cruise, PO owner told me it worked 1 time, then quit (he only owned it 6 months). well the switch was broke, so duh it didn't work?
flyboy1100
UsA
me
k1500
Cruise solo doesn't work, need to troubleshoot it. Still no idea where the hose should be running. Really just need a pic
Sent from my SCH-I605 using Tapatalk
Boone83K10
Boone, NC
Benjamin
I assume you are talking about the vacuum release hose for the cruise brake pedal switch.
The hose runs from the servo, up over the brake booster and in through the firewall at the hole above the speedo cable. it then runs up over the steering wheel under the dash and down the back of the dash next to the radio.
I took my entire cruise off...make sure you every component in this picture. the red box (cruise module) is bolted above the gas pedal and the yellow box (speed sensor) is up in the dash.
flyboy1100
UsA
me
k1500
Thanks, that's what I needed, the hose is way too long to be all underneath! I need to take my cluster back out anyway because the wire for my gas gauge seems to be loose.
I think I have all of it, it there is a single pin not connected to anything on the green speed sensor thing, will double check the rest when I have the dash out
Boone83K10
Boone, NC
Benjamin
the single pin goes to the back of the speedo, right beside the cable connection. it actually gets screwed into it by a small bolt.
flyboy1100
UsA
me
k1500
I have something up the already, Not sure on pin count, but it is connected
Wrenchersllc
