- Sep 18, 2018
- Conroe Texas
- Mike
- C10
I just finished reading a 24 page report by Lars Grimsrud, a GM engineer, titled 'Timing & Vacuum Advance 101'. It's mostly over my head and it left me with a few questions that some of you gear heads may be able to answer. My setup is mostly original with about 56k miles. The emission system has been removed except for the canister. It has a re-manufactured QJet from National and a new HEI distributor to replace the original ESC unit. Currently, the dist. gets vacuum from a port at the base of the carb and measures 0" at idle and around 10" at 3000 rpm. Manifold vacuum is 19.5" at idle. Timing is 4 btdc with vac line removed and plugged. The truck starts well and runs okay except for dieseling every now and then.
This GM engineer says that for max performance, distributors should ALWAYS use manifold vacuum. What do you guys think and would it be worth the time and effort to make the change? What should the timing be set to and what will happen when the vac line is connected with manifold vacuum? Thanks for your valuable time.
