Converting K5 Blazer A/C to R-12
ripple1973
San Antonio
Douglas
K5 blazer
Hello group I am getting ready to convert my R134 system back to an R12 system would a flush be necessary to complete this? Also i am assuming that I will not need to change compressor, which is a year old. I am just fed up with the poor performance of a R134 system in my blazer. I tried everything parallel flow condenser. It sucks to not have a good a/c in Texas.
Sent from my Nexus 6P using Tapatalk
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Yes you will have to flush. Once you open the system it becomes contaminated. The compressor from what I have been told should be fine once flushed. You should also get a new oriface tube as they too get clogged and contaminated...at $5 its cheap insurance. These evaporators operate more efficiently with r12 than with r134. Before I went full on r134a from r12, I wasnt able to source a viable compressor since they are all built to use with r134a. Fwiw my system cools down to 40 degrees without any problems other than the fan not blowing at the force like my late 3 year old truck.
smoothandlow84
Steve
Going price of r12 here in az is hovering around $40 per 12 oz can
ripple1973
San Antonio
Douglas
K5 blazer
40 bucks can is so worth it. It is a daily driver and it is 105 today out today in South Texas and this 134a is not cutting it and I hear some horror stories about people using r12 replacement product that are basically propane.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I think that’s Freon 12 that you’re talking about. I hope the conversion back goes well. I wish it was thirty years ago, and R12 was still the norm. The price gouged stuff (R1234yf) that new cars have to switch to by 2020 (?) seems more complaint worthy so I won’t talk too badly about R134a.
yevgenievich
Place
Name
Year
Model
Size
With a bit of work, stock system can handle all but parking lot idle with 134 freon when outside temp is aproaching 45*C. After complete flush and new orifice tube/dryer/oil fill should be fine for use with r12
smoothandlow84
Steve
You will need 4 to 5 cans for the complete system....so figure on $200, that is of course unless you have a leak
highdesertrange
kalifornia
mike
k30
replace your orifice tube and your receiver dryer.
have you tried an aftermarket fan in front of you condenser? that usually works for the ones that have been converted to 134.
highdesertranger
yevgenievich
Place
Name
Year
Model
Size
Red tube. Aux fan, and parallel flow condenser were almost enough for my suburban. For a converted halfton short bed, just blue orifice tube and clean stock condenser was enough for texas heat. Both with 134. 89 TA blows 5* C in 42* weather in light traffic, 10*C in heavy traffic.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Is this blue orifice tube a generic part that can be bought at the parts store?
I am thinking I will try that as the ac sucks on traffic.
Ironically, the engine cools off when in traffic- makes me wonder if the lower hose might be collapsing...
Or if I need a 180 stat.
Fun times!
yevgenievich
Place
Name
Year
Model
Size
95 ford f150 would pull up blue orifice tube. But before making changes you are welcome to post exact current configuration, out side vs vent temp information and low side/high side pressures during operation. Might help to ensure everything is doing its best by going through everything.
Fun times!
yevgenievich
Place
Name
Year
Model
Size
Also if engine is getting too cool at idle for some reason, the clutch fan might stop pulling much air reducing efficiency of the condenser. Aux fan helps decently as well for idle operation.
ripple1973
San Antonio
Douglas
K5 blazer
I do have a parallel condenser and got a new fan clutch. Do yall have the can or flat compressor?
ripple1973
San Antonio
Douglas
K5 blazer
Or in yalls opinion do you think that matters
holy6hxst
