Converting auto column to floor shifted
RADustin
New Orleans
Dustin
C20 Crewcab
Can a '76 auto column be 'converted' to floor shifted? Basically I want to remove all the guts of the auto column and change the piece that holds the shift arms.
Is this possible easily or should I just look for a new column?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cut off the tab and make sure it's in park and the ack weld the tab remains to the housing or just tack weld the tab to the housing with out cutting it. Pop out the pin and remove the lever inside. The nub for the shifter makes a good tach mount.
What kind of shifter are putting in it? You will have to pull wire from the switch on the steering column to get things like the P N safety switch and back up lights. It's a PITA, but do it right. Route the wires under the carpet to the shifter cover and then wire in your micro switches and it'll work flawlessly.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I usually leave the neutral safety switch right where it's at. When I get out I clock the column to reverse instant immobilizer.
RADustin
New Orleans
Dustin
C20 Crewcab
Was a tilt floor shifted column ever offered factory?
I'm going to rewire the entire truck with an American Autowire kit to remove the glass fuses- so I'm not too concerned about the wiring aspect.
For manual transmission yes, but not for Automatic. So your switch that controls the P N Safety Switch, so you don't start it in Drive or Reverse, and the back up lights are on the column on the half moon switch. Eventually, that's what I'd like to find because I have all intentions of running a B&M QuickSilver shifter and that shifter has it's own micro swtiches built into it for the back up lights and P N Safety.
RADustin
New Orleans
Dustin
C20 Crewcab
yes that's fine.
I'm going to use a Lokar floor mounted shifter.
entertaining the idea of switching to a much later column that would have wipers and cruise control on the stalk. This would help me out.
but- I don't want a plastic column. So this may not work either.
So then you're wanting to go with an 84 or later column where the wipers and bright light switch was moved off the dash and floor to the multi-function switch aka the turn signal.
BTW, the column isn't plastic, it's an aluminum housing, but it does have a plastic cover just behind the steering wheel and over the multi-function switch. It's really not all that bad. You don't even realize it's a plastic cover.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
MikeB
The part of the column that the shift arm attaches to is called a "shift bowl". "Blanks" are available. They are called "BOWL STRG COL FLR SHIFT".
Here's a picture GM 7812754, but I think it's only for for 81-83 non-tilt columns.
RADustin
New Orleans
Dustin
C20 Crewcab
is there anyway to get the part number for a blank shift bowl for the earlier columns?
Is there any chance the bowl from a not tilt will work on a tilt?
I can find non tilt floor shifted columns, but not tilt. My factory one is tilt- so I may be able to combine 2 into 1.
RADustin
New Orleans
Dustin
C20 Crewcab
can anyone confirm the material of the early style shift bowl on a column shift tilt column? I'm thinking I can grind off the lug on the bowl and braze it up, but I need to know if its pot metal I can use silicon bronze and if it's aluminum I'll have to use something else.
twitch1989
