r67northern
- Aug 29, 2013
- Louisiana
- Leland
- Suburban r20
Hi All,
This past weekend I went through a condenser replacement on the '90 Burb. I had a couple of interesting experiences along the way so I thought I'd post an update. The background to the burb's system is that it was converted several years ago to R134a and over the past few years has had everything replaced except the condenser. I've done most of the work myself, but occasionally farmed it out.
I decided it was time to replace the condenser when I fixed a leaking evaporator (full disclosure: I farmed that one out because of some time constraints) and it still wasn't cooling well. I couldn't afford to throw more money at someone else to work on the system so I ordered the parts, took a day off work, and went after the condenser myself.
The part I ordered is the "OE" ACdelco unit:
http://www.amazon.com/dp/B000C9DGMI/
It arrived and it was much smaller than the original. The height matched well, but the length of the unit (side to side) was reduced. The fin design is also highly updated and I expect that its total heat exchanger area is as good or better than the original that came with the truck. Still, mounting was going to be an issue because of the size change, despite the fact that delco promises this is original equipment. Here's the original that came out of the '90:
Since I'm an engineer I can convince myself that heat exchanger technology could improve in 25 years so, if I could get it to mount, I'd give it a shot. It turns out that you can re-use the mounts for the condenser IF you move the brackets from the original outer bolt holes to the most inner holes on the truck's front surface.
The lower brackets are not bolted in place, but are held in place with some tabs and slots much like the radiator. The passenger side lower mount had unused slots that I could re-purpose for this new condenser design. The driver side required that I use the rubber mount without alignment slots. So far it is holding without problems.
Here's a photo of one of the mounts with the new condenser installed. The mount has been moved from right (original) to left (new) positions to hold the condenser centered in front of the radiator. The view is basically from the top to the bottom, along the passenger side:
With the new condenser centered, the hose lines match up to the original compressor lines well. The upper mounts also align fairly well to some unused bolt holes. Here's a picture of the condenser installed (a trans cooler is attached in front of it):
So the upshot is: the new design will fit if you don't mind moving mounts around. The new design also cools well, and the a/c is running much colder than it has in the past few years. I hope that helps just in case anyone feels like using an "OE"
delco unit.
Now I need to think about getting the old girl repainted!
As an Amazon Associate we earn from qualifying purchases.
