Shoote
- Sep 18, 2021
- florida
- tim
- K10 C10
Hi,
I could use some help, it is getting hot in Florida. I replaced the ac evaporator on my 1987 V10. It has a Sandeson compressor. The system blew very cold but had a small leak at the connection by the orifice tube. I removed the 134a and thought I would replace the orifice tube while I had the system open at that location. The orifice tube would not come out. I tried everything and every tool with no luck. I bought the GPD evaporator and installed it. Vacuumed down the system and added 32 ounces of 134a. The ac blows cool, not cold, but the issue is the compressor does not cycle off now and the low side pressure is at 55 while the high side pressure is at 50. I did not add more 134 because I did not want to have the low side pressure go higher. Those pressures are at idle. As rpm increases the low side will drop to 40, but the high side does not change pressure. Any idea what is causing this issue?
I have to do the same thing on my 1985 and don't want to have the same problem a second time.
Thank you!
Thank you!
