Chuck’s engine build thread!
ChuckN
Bellinham, WA
Chad
Cam bearings turn at 1/2 crankspeed and don't see the abuse that rods and mains do. No pounding,just turning. At work we replaced them probably 90 percent of the time. At home I may do them 1/2 the time.
Yeah we”ll take a closer gander at them today. I was as gentle as I could be when removing the cam, but there’s no saying I didn’t score something with a lobe on the way out.
That is true that LS's are line bored after the bearings are installed at the factory, so it's not uncommon for them to show some copper and be perfectly fine. I didn't do the cam bearings in the 5.3 in my C10 but I did do them in my '05 just because they felt like 60 grit sandpaper on the top. Probably still woulda been fine but whatever :33: I'd definitely always do cam bearings on anything else.
Nah, you're fine. I've watched buddies remove and install cams not being careful at all, clunking and banging around and it's been fine lol
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Probably only if there is a lot of scoring
bluex
Spartanburg SC
C15
3 cam bearings came out with the cam on the last 6.0 I did. They installed an updated wider bearing an honed it after they were in so the new cam spun freely. Said he's done a bunch that way that had spun them :shrug:
ChuckN
Bellinham, WA
Chad
Long live the Swiss Army knife of vehicles, the minivan. Off to the machine shop.
He said it will need to be bored. So he’s going to hot tank it as well and put in new cam bearings. Might as well start off with a clean slate.
xm20k
Girard, Ohio
If I'm doing a quick refresh in the garage ie dingle ball hone etc. I don't touch the cam bearings unless there trashed.
If the block is going to the shop for more work than a dingle ball hone it gets tanked and new cam bearings.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Ha ha ha, why do they call them "mini" vans anyway? They aren't mini by any stretch.
Behold the multi purpose vehicle. Covered transport in my mind. This was back when mama's hardbody had a defective transmission
Fat 454
Australia
C20 Suburban
My wife would kill me if we did that. Its the only "nice" vehicle we have ! ...( she won't drive any of the trucks ...)
Radiohead
MCMLXXIX
Lol. Nutty as it sounds, it was her idea. Gotta keep on doing farm stuff, the world won't wait. Yeah, mines a keeper. But guess who had to do the clean out?
Yeah....
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Back in the day, we had a caustic "hot tank" at the Chevy garage. Not sure what was in it but it was hot and if you got that sh!t on your skin, given time you may end up with your bones....it was brutal!!! Any way rebuilding my "race car" 327 I took it all apart, left the cam bearings in, put it in about 4 PM, turned the heat off at quitting time and tanked it overnight. Went in early pulled out, hosed it off and let it dry. Put it together the next evening and left the cam bearings that were tanked, in it and ran it that way all season....NO problems, good pressure, ran 12.90 in my 56 210 2 door wagon...............Ignorance is bliss:rolleyes:
ChuckN
Bellinham, WA
Chad
While I have the engine out- any idea for the best cleaning method of the engine bay? I’d buy a power washer but and roll it outside but unfortunately 2 feet outside the garage is a steep 10 percent grade so that isn’t an option.
Simple Green? I hate the thought of just spraying a whole bunch of brake cleaner. Just the usual years old caked on grease and dirt. Thought I’d ask here what people would suggest. Preferably something that would get me towards some paint prep too. Thanks in advance.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’d scrape the heavy stuff, then get a weed sprayer and some super clean (a little harsher than simple green in my experience), spray it on, let it sit for a little, scrub it and spray it off with a hose or another pump sprayer with clean water, dry, if pretty rusty hit with some phosphoric acid, scuff with some horsehair and once dry paint it with a coating of your choice.
I used Super Clean on mine, it worked very well. Didn't even use a pressure washer, just the hose/super clean and various wire brushes till I was happy with it. Then let it dry, gave it a quicky wipe down with some laquer thinner on a rag and then used VHT Chassis Black on the rails and crossmembers
samelthecamel19
