C20 CREW VS C30 CREW, is there a diff?
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
since they both use the one ton frame and 14bolt rear, is it just the spring package?
That's what I've always assumed.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i know the 1 ton has bigger rear brakes then the 3/4 ton does
Yeah, but you could get the bigger brakes on the 3/4 ton too.
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
3/4 ton usually have a simi flotting axle, 14 bolt axle, 1 ton. Has full flotter axles. The ring and pinion is bigger to. There may be extra coolers, on the trans, and or engine oil cooler.
Big blocks and diesels got the FF, even in a 3/4. All of the 70's trucks got the FF.
So you're saying a C20 crew cab with a 350 got the SF axle, even though they got the 1-ton frame and rear spring perch spacing?
X-cabsquarebody
Western NC
Billy
305 TPI, 454, 8.1
No, just trying to point out some outer possible differences. Spring stuff was already brought up.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
My 86 K20 has a 14ff with a 9 leaf rear spring pack and 13 inch rear brakes
Kapdin
North Dakota
Lance
Yea i got 2 14bff, one out of a 73 3/4 based on the axle code with smaller drums (wich is in my truck now) and one from a 75 3/4 large drum. both 10.5" 4.10's.
alwaysbroken
