Bvllsh!t on craigslist.
Status
Not open for further replies.
Moderator Administrator
Moderator
http://austin.craigslist.org/pts/3272510052.html
Probably show up on the free stuff pretty soon...Or it will sit out there and rot. Never seen a wind deflector and roof rack on one though...
Hmm, I've seen several with both. I'd love to have that top for mine.
$400 a bit steep isn't it?
Yes, it's steep. Although, the slider windows, roof rack and deflector all have value. To the right person, it's probably worth $300 or so... that's what I'd be willing to pay if I came across one. Most tops are only worth about $100 or less.
79K10
Sacramento,ca
Ryan
350/th350
heres those power doors ive been offered for my manual ones...
he said the pass side works
driver looks pulled apart, he said its not working
ugly but straight looking
i need to paint my truck anyway. so doors and $20 for my manual doors off my donor truck
I really want power doors for my truck... if its too hard to make it work i can always sell these for 40 bucks and get some money... i hope
Yeah, I'd say you're safe. Even if you don't get it done, like I said, most buying doors are buying them for sheet metal. So if his sheet metal is good, you're good to go and won't lose. Chances are, the driver side has a bad window switch if neither driver or passenger door worked on that side. Or it lost a ground. LIkely minor. If it's just the driver window, then probably the window motor. Also cheap from Pull A Part lots if you they have a good battery to test them with.
The way he cut out those rear wheel wells,, I'm thinking he gonna run tracks instead of tires. :roflbow: Good thing it's a long bed or it wouldn't have a bedside at all.
Yah, you beat me to that. Friggin hack job. Wonder how he got fender flares to fit it, they make them custom sizes?
79K10
Sacramento,ca
Ryan
350/th350
do you know an easy way to hook up a battery to the doors to test out the motors? thanks
Moderator
Those are Bushwacker Cutout flairs, the rears are a bit on the large side for my tastes, but that's how it's supposed to be.
I'm sure those pudwackers come in different sizes and I'm sure he got them for 44's. Looks hideous with what, 35, maybe 37in tires.
Status
Scrambler-Cafe
