Brush Guard, watchu tink?
Leave the grate, or cut it out of the brush guard?
  • Grate
    Votes: 10 90.9%
  • No grate
    Votes: 1 9.1%
  • Total voters
    11
scrap--metal
MN
Calvin
'85, '81
K10, K20
Can you use a Rivnut?...I think that's what they are called. It's like a pop rivet, but it has threads...
@Turbo4whl 's suggestion looks like the original mounting design. I think it's be safest to replace the rotten cage nuts once I get some measurements.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Does anyone know where I can find some captive nuts/threaded clips to use with these square mounting spots?
The threaded clip behind there now spins and looks to be busted, which surely motivated the torch removal.
There's no way to get a carriage bolt behind it, even if the rubber bumper were removed from the front, and I think there has to be a better way than welding some nuts inside. Right?
You could cut a slot in the metal with a cutoff wheel, so you can slide a new carriage bolt down.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
There should be a hole directly behind it where you can pull off the rubber strip and put in a new one.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Yeah, on the factory Chevy bumper guards (bumper tusks), if you remove the rubber strip, theres an access hole. Maybe yours is the same?
scrap--metal
MN
Calvin
'85, '81
K10, K20
Unfortunately, there aren't any holes behind the bumper thingys on this design. I did specifically check for 'em.
Gonna get me some cage nuts.
scrap--metal
MN
Calvin
'85, '81
K10, K20
I found and ordered some cage nuts from Grainger on Monday, and picked them up yesterday over my lunch break. I couldn't find any designed to accommodate the ~0.2" plate, but I got some that were close and tweaked the steel cages by hand (pliers). That was much simpler than getting the old cage nuts and torched bolts out. There's limited clearance between the cage nut and the steel behind it, which made it a PITA. This also means proper mounting bolt length will be important on the top bolts.
It's ready to go on now whenever I can make time to mess with it again, or I have to cut the grate out. I still haven't decided on that.
Pix...
Cleaned out the old hardware
Cage nut comparison before and after reshaping the cage a bit. I got a little better hook/grab on the cage by bending it to final shape while it was in the brush guard.
Ready to go.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
No way in hell would I cut the grate out.....it'll be interesting to see what you decide. Are you aiming to modify if before mounting?
No before and after pix?
scrap--metal
MN
Calvin
'85, '81
K10, K20
Easy big fella'! I ain't got it on the truck yet. I'll post before/after pics of the truck when I get there. I went fishing last night and didn't have time to mess with it.
I think I'm going to change focus to my windshield this weekend while I stew on the grate decision. To cut the grate out nicely, I'd have to do it off the truck to have good access to the welds. There's only four small welds on each side grate, and six small welds on the center grate. Maybe I should mount it and then decide? It's just a little more messing around, right?
Why you like the grate so much? Can't cook on it or shred cheese with it... Maybe I'll make a poll for the brothers to speak their minds.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Bigger rocks, sticks and tweety bird/pheasant protection. If you're into that sorta stuff lol
scrap--metal
MN
Calvin
'85, '81
K10, K20
I can dig that, but the grills in my truck are not in great shape as it is.
I thought all MN pheasants had migrated to the Dakotas until I had a hen fly across the road in front of me last weekend. It was the first time that's happened in a LONG time.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
They're definitely up in numbers here lol.
67ventwindow
Missouri
Kevin
C30
After reading your post I picked up one myself. The bolt holes line in the bumper, I want to keep the grate and see if everything lines up well. Then I think about a repaint.
scrap--metal
MN
Calvin
'85, '81
K10, K20
I got the brush guard mounted over the winter, and finally got the truck outside for a picture. It was certainly worth the modest investment.
dudleyrushmore
