Brake Pedal Does Not Fully Return
AJ 3
Battle Creek MI
AJ
C 10
I just purchased a 1977 C30 Quad Cab dually with the factory 454 and hydro-boost brake system.
Currently the brake pedal does not fully return. The PO solved the problem by installing a pedal return spring. Is there an adjustment on the push rod somewhere so I can remove the 1-1/2" of play in the pedal.
Or do I have a bigger problem
quaddriver
Cook Forest PA
Ed
Chevy R2500
The big one
other than a stuck spool valve inside it, was it perhaps replaced where the actuating rod is a different length?
AJ 3
Battle Creek MI
AJ
C 10
Is there a possible way to unstuck the spool valve?
Yes someone could have change something with the incorrect part. The whole master cylinder, booster, and brake line assembly all look like they aged together. Everything all kind of has the same surface rust over all the parts.
AJ 3
Battle Creek MI
AJ
C 10
After removing hacked up after market electrical gismos and nasty wire splices. I was finally installing all my dashboard back together again.
Then I noticed my brake pedal is hitting the AC duct and making my brake lights illuminate due to PO installed pedal return spring. Also I noticed that my brake light switch and cruise control sensor are pushed all the way rearward.
So with adjusting the brake light and cruise switch to where they should be. Plus removing the PO installed brake pedal return spring. Everything works correctly my brake pedal was just moving farther rearward than needed due to miss adjusted switches.
PO's Crack me up. Let's install an extra spring instead of solving the problem.
Shak379
