Best Gasket Sealer
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I getting ready to replace the gasket on the rear end on the 85 C10. Which would be the best gasket sealer, Permatex High Tack or Permatex Gear Oil RTV?
scrap--metal
MN
Calvin
'85, '81
K10, K20
In my experience, rear end covers are pretty easy to seal. Just about any RTV/gasket sealer should work as long as the diff isn't filled to soon after assembly. No gasket necessary.
If you're eager to dump fluid in it immediately after sticking the cover on, use whatever sets up the quickest.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Will not be refilling immediately. I have both sealers.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Always been a big fan of the gray. Never heard of this right stuff till now, I'll be trying it for sure. Thanks!!
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I ended up using the Geare Oil RTV.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I use right stuff. Be prepared for a slight fight to get whatever it's sealing off. But id take that trade off any day of the week.
Doppleganger
OH-MI: Just like it sounds
Anything diff, trans or transfer case that leaked.....the Permatex Gear Oil RTV always stopped it for good. Anything else leaked.....eventually.
Octane
Atlanta
Eddie
I use gear oil resistant rtv. I used to just use a gasket only. But it was just such an ordeal to make the local partscounter jockey get a 12 bolt gasket, instead of the 10.
Daron58
Ponchatoula La.
Daron
250 I6
High tack all the way use it for all my stuff rear diff cover,side lifter covers,valve covers, oil pan etc. one time and done when re-sealing anything
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Ive been using Permatex “Gasket Maker” and it’s done well. That’s what came with the Spicer differential bearing kits I bought for my Jeep.
Ultra grey is my go to. It's good stuff.
This too
ETA: I also like the “Lubelocker” reusable gaskets that don’t need goo to seal.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
I read recently about an idea of helping an RTV sealed area not leak. Don't fully torque the bolts, but allow the RTV to "firm up" then torque to spec. I do have to second the Lube Locker gaskets, I have not had one leak yet, and they are reuseable if taken apart carefully.
imyourhuckberry
