bad luck with both my squares at the time!! burning up HEI module.. WHY?
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
been working out of town since last year. No love for the 87 1500 or the 85 2500. I've been coming back on the weekends from out of town. a couple week ago i took my 87 out and it just died on me.. still not running. Thats another story..
Took my 85 2500 5.7 out last week to get my wife some dirt. It just stopped while driving. Got a tow truck got it home and there was no spark. Changed out my cap rotor and coil.. Still nothing. Bought a new spark module and it worked fine. Ran 10 times better. 4 miles from home going to get dirt driving on freeway it started popping real bad like the spark plug wires were crossed even at low RPM, then it just died. Got it towed home Same exact thing, the module went out. Got a good 1 from my friend and it burned up 12 miles later..
What could cause this?? My truck ran like a champ.. Well it did lol.. never had problems or hot rod the hell out of it..
Any ideas??
Georgeb
Wisconsin
George
K10 Burb Z71
is the ground good for the circuit? Is the charging voltage normal or could it be high?
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
1. is the ground good for the circuit? In the DIST??
2. Is the charging voltage normal or could it be high? Not sure. If I pull the ALT and take it to auto zone is this something they can check? wont run unless I put another module.. So cant tell now.
Thanks. :cheers:
1986ChrisK10
Mississippi
Following this as well. I was using the truck around the property. *waiting on title from orig owner* Anyway, I was at the road unloading the yard garbage and hoped in, gave it a little gas and poof, DEAD. Truck has sat for a long time before me getting it from orig owners. Wouldn't even come to life with starting fluid. I am guessing we have about the same issue going on.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
going to swap dist with another GM HEI dist, see what happens. I will let everyone know. Been reading alot about bad pick up coils.:cheers:
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
dose the dizzy shaft have any movement (slop) in it ??? if so the pick up can get damaged and short out that is a bad problem with the efi dizzys
workinman789
