Backfire
Zukeman
Ferndale WA
1977 chevy K10
Cheyenne
350-5.7 ltr
Hi. I have an automatic 77 K10 with stock 350 and Edlebrock. Truck is up and running after sitting for a few months.
It has a new fuel tank, fuel, fuel filter. Truck now backfires when slowing down. I hit like 65 mph, took foot off gas and several small pops from exhaust. Any ideas to try first ?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Sparkplugs
Zukeman
Ferndale WA
1977 chevy K10
Cheyenne
350-5.7 ltr
I ran it today and I can hear a leak at driver exhaust manifold. Thank you..mike
fast 99
Spokane, Washington
Take it off, get it sanded flat reinstall using high temp silicone. DO NOT USE GASKETS.
Most of those manifolds do not have the cast in tie bar. If yours doesn't get a set of spreader tools to line up the bolts. Even then you may have to enlarge the holes. Or optional, get a new manifold.
WP29P4A
Nevada
Sierra Classic V1500
@fast 99 After working on all kinds of vehicles for over 46 years I'm a little embarrassed to ask, but, What is a "cast in tie bar"? What are you spreading with the "spreader tools"?
I fully understand the "enlarge the holes" been there done that several times.
fast 99
Spokane, Washington
Top is with bottom without.
fast 99
Spokane, Washington
spreader, goes in between openings of manifold. It's right and left threaded. Only for installation, remove after tightening bolts. Need 2.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
And don't be meat headed about it. Get too happy with it and dink. It usually takes just past a little rch to get it to fit right.
Useenamez
