1985 305 keeps dying after a few seconds
rys272
saskatchewan
rylan
wrangler / sierra classic
Had her running absolutely mint for past few months. Had literally drove around for a few hours the night before fast forward next morning I start her up and she just instantly keeps dying unless I keep my foot hammered on the gas.
Black smoke out of exhaust
Valve cover breather smokes hard
Gas leaks like crazy out of side of carb all of a sudden like a waterfall amount
Choke is staying on? Has new electric choke
Fuel pumps good
Fuel filter is good
Never had old/bad gas in it
When it comes to carb I got no clue what I’m doing what so ever Thinking has to be something with carb/choke
77Dmax
vt
Joe
The float is stuck open. Whack the side of the carb with a wrench. You should check the oil for gas also.
rys272
saskatchewan
rylan
That one vid is the longest it’s ever ran usually starts instantly what’s happening it takes like 10 cranks than starts rough as **** and then will idle up and run somewhat okay and then slowly almost sounds like it’s bogging hard and is deprived of like fuel or air and then dies UNLESS u hit the pedal
And no it’s not out of gas
rys272
saskatchewan
rylan
Banged all around carb hard same thing still dies gonna give her a go again tommorow but if that doesn’t work is it time to take it off?
75gmck25
Northern Virginia
Bruce
Disconnect and plug the fuel line so you have no gas coming into the carburetor. Then start it up and see if it smooths out and runs until the float bowl is empty. If it seems to idle and run fine, then it’s definitely a problem with the float, needle/seat, etc.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The choke isn't opening all the way. It should stick straight up and down basically. Did you adjust it properly?
77Dmax
vt
Joe
Watching the first vid the choke appears to be working close to correct. It doesn't sound like the fast idle cam engaged though. It should be running around 1100 rpm. Sounds like its puttering at a normal idle.
Also didn't see a waterfall fuel leak.
85 Fleetside
Indiana
Scott
FWIW, sticking EGR valve did this on my 4.3L. Low manifold vacuum at idle to 1100 rpm was one of the symptoms also.
If it's pouring fuel out, it is flooding,the only things that can make fuel pour out of the carbureator is,needle and seat,float,or excess fuel pressure. If tapping on the carburetor didn't make the flooding stop it's time to pull the top off the carb. Unless it has recently had the fuel pump changed,in which case I'd recommend checking fuel pressure,lots of the new pumps are out of spec.
Geoduck
PNW
Rylan, try snugging down the screws attaching the carb airhorn and the four that attach it to the intake. My guess your carb needs a rebuild but checking the bolts costs nothing. It may only be a vacuum leak.
Good luck and let us know what you find out?
A vacuum leak will not allow a float bowl to overfill. The only things that will cause the float bowl to overfill( waterfall amounts of fuel pouring out as per your description) are needle and seat,fuel pressure,or float.
rys272
saskatchewan
rylan
Hadn’t touched this thing since I made this post been busy fixing my other truck but let her sit for the past few weeks finally was like let’s see if she runs threw a battery in it beat the absolute piss out of the carb with a mallet thing fires right up like u wouldn’t believe no more problems.
Obviously need to take carb apart still but this things getting a fresh 350 so not too worried about it as long as it runs.
thatgermanguy
