Aux Battery Tray
Conejo_K10
So. Calif
Pete
I have found that the factory auxiliary battery trays are no longer available. Fortunately the support is still available. If they make the support why don't they have the trays[?!].
Anyway I'm curious if anyone has added an aux battery and if so, what did you use for the tray? LMC sells battery trays but they're actually right-side trays.
model: 75 K10
Keith Seymore
Motor City
Keith Seymore
4.3L
You might find the tray portion itself (the horizontal part) is common LH to RH, and that it is the support that makes it one side or the other.
If that's the case you could get any available tray, cut the bottom off and add the appropriate support to meet your need.
Just a thought -
K
dvdswan
Port Orchard, WA
Dave
You could hit up the local junkyards and find one possibly.
The auxillary trays in later years were smaller I think. I have 2 passenger side 73-80 trays and my actual battery tray was fabricated with a support from a tray and some basic steel or taken from a 72 and older truck.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
i just build all my own trays from simple angle steel stock pieces(i use bed frame metal) and flat steel. easy/simple, it only takes about 15 minutes to make one. and tons better than any factory or aftermarket crap ones., have two trays in my 75. two batteries., with an alternator charging isolator i salvaged form a motorhome. one battery for starting and the other for everything else in the truck,
eskimomann209
Modesto
Marcus
Prove it, post some pics.
:p
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I have few in my parts heap plus the trucks in my yard... they're almost all different..!? Obviously many variations. I can't verify it right now but I'm suspecting that for example, factory aux battery vs Camper Special option (which has an aux batt) vs C/K10,20 or 30.
BRetty
Los Angeles
Franklin
They have a aux tray, but it's for an 81-87.
I find it odd that there are aux trays for 65-72 and 81-87, but there are none for 73-81?
Others have found an odd dearth of parts sepcifically for 73-81 trucks. Both LMC and Classic industries seem to have big caps in their catalogs.
Not sure why.
Regarding batteries, my tray is mounted sideways with mystery brackets and I can't figure out where it came from. I keep meaning to replace or get a cover or just replace my far-too--large battery I bought by mistake, but have been too cheap, also the idea that while I'm doing that I should inatall a second battery, isolator, kill switch, upgrade headlight harness, many things tbd.... Someday.
B
Termite_Delight
Lanark Ontario Canada
K2500
5.3 L33, 4l80e, NP241c
Joestreml
