AuroraGirl is buying another square... is it a good one?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
It does. Need to get a radiator for it.. but guess who has like 5 on shelves!? The only big block one i have after i fix my current one is a 2 row but its the thick 2 row so i read thats potetnially good
From your pictures, do you even need a ******* radiator?
Everything's always covered in snow. Just let the air cool it down, pack a bunch of snow around it, sometbing
@Rusty Nail i think you and i both know the real candidates for this truck are the flathead v8 ford and the 2 speed powerglide, i mean, we arent savages of course.
Or maybe flathead 6 out of a 40s dodge truck
**** it, oldsmobile 260 @Matt69olds watch out im gonna beat you in a race
Might have bad heat soak that way, might need to do a dual snorkel
Vbb199
Salisbury NC
Vince
okay well block pontiac, they dont have small or big? Its big by means of a 350 but small by means of 454
The displacement of Pontiac motors is obtained by changing cranks, bore size, rod length, etc.
Take a look at a Pontiac 355, then a 455, you'll notice they look similar in siZe.
Edit : that's to the best of my knowledge, I'm not a Pontiac man.
But I will say dad's pontiac 350 sitting on the floor is the same size block as the 455 short block he's got.
yes from what i gather the only external difference noticeable should be deck height and accessory spacing(depending on heads, intake)
Vbb199
Salisbury NC
Vince
Right, I failed to add that. Deck height.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I believe Pontiac’s have the same deck height/block dimensions across the entire line. The bore,stroke, piston pin height, etc determines the displacement.
the Olds engine family has a small and big block. The 260,307,330,350 and 403 are small blocks. The 400, 425, and 455 are big blocks, with a 1/2 higher deck height. All the exterior bolt patterns are the same.
I think there are engine families with the Buick engines. I’m not familiar enough with them to even begin to discuss it.
No one was listening at the collab meeting when buick said "hey we mount the distributor in the front and it works really well, imagine 4wd trucks" and suddenly talked over by the guys who said "We NEED to change temp sensor design, STAT."
Vbb199
Salisbury NC
Vince
Ford = front sump
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
I live in Alabama and have seen worse for 800 bucks. Granted there are many many better options in the south but that one isnt THAT bad for a northern truck. I cant see much in the pics and it could be hiding some serious rot...however you seem to be ok with that so git er done.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Just what you need, another vehicle. Bonus of it being an incomplete nonrunner that was someone's parts truck with a lot of cab rust.
Score.
If it's only missing the engine, trans, the steering column, tailgate, oh and floors. As if that wasn't enough. Where's the gas pedal? What else is it missing?
The guy is holding it for you because nobody else is blowing up his phone over it.
I don't get a good feeling from it. :33:
Vbb199
Salisbury NC
Vince
Reckon it's all subject to the work involved.
A truck like that, in that disposition here?
3-500$.
Up there, it might be worth more considering it hasn't collapsed on itself from rust and there's a truck from the door handles down.
Smitty69
