Rusty Nail
Cowboy of both Time and Space
- Jan 29, 2015
- the other side of the internet
- Russell
- C20
- 350sbc
Cool bro.
Those two roadies shown would be of the lt1 variety fyi. A whole nother problem child engine.Dude...
No.
Do yourself a favor and build a 1 piece RMS block. 87 - 92 LO5. The dipstick switched sides and the timing cover is different (oil pan) from a 2 piece RMS block. You'll have to make certain the fuel pump pushrod (pump BOSS) is drilled through because some (most?) were NOT. BUT that's not a deal breaker - your machine shop can fix it NP but be aware of that potential pitfall.
What you REALLY want is an LO5 block out of a big body CAR. This may be factory roller cammed, one piece RMS, maybe oil cooler- and if you look long enough you can find one with the pushrod hole drilled to mount a mechanical fuel pump without delay.
Think ROADMASTER , PARK AVENUE - C and B body cars , Caprice, Impala, even some Cadillacs had Chevrolet LO5 engines. Take your time and you can find the right one. Build a car motor and put it in your truck.
All 350s were NOT created equal - contrary to the other replies in this thread..i'm here to help and know what i'm talkin about lol.
Build an early LO5 out of a car.
87-92 but really 1988 CAR engines MAY be roller motors, no truck engine will be - dont bother looking. That hard part has been done for you. Car engines only.. 87 may be too early 92 may be too late. 1988, 1989 prolly the best shot at a roller motor, drilled fuel pump boss. Unicorn carb motor in a TBI car. They're out there..a bunch. Lotta lookin. 87,88,89..
Camaro and Firebird have good LO5s and in my experience those pushrods arent drilled but thats where the good heads come from.
#083 is the best cast iron not vortex cylinder head ever made. That's what you want Screw vortex. Trans Am ,GTA, IROC, Z-28. #083 F body heads on a 1988 L05 out of a Roadmaster.
Good luck.
Hope this helps!
These cars had BAD.ASS. 350s.
"Euro" front end Caprice? Rounded turns. Yeah baby!
Google image results for 1988 Roadmaster
Interesting. Knowing this information, I guess my question then is what is the difference between all the gen i engines. I know I don't want to try an LS swap or TBI swap, but I am curious whether there is a difference between the 350 engine in a 1967 chevy truck vs a 1978 350 in a truck like mine? were there any performance upgrades done or are they all exactly the same year to year?gen i, gen ii, gen iii.... gen ii being your tbi. gen 3 being LS family. Confusing, Gm is producing new gen 2 engines called gen 1.... but they were late late gen 2... its weird.
Square bodies were all fitted from factory with gen ii, you should have little trouble getting any gen ii to work. if you go carbureted, easy peasy. if you want to retin tbi you have some work but not a terrible amount of it to go., Just know that BOP engines have small block 350s as well and only the oldsmobile 350 diesel was used in a square the rest never touched them but can be made to work if you are invested
Well Google is ******* retarded then. There weren't any 88 roadies. Caprice name ran continuous through the years, roadmaster did not.Google image results for 1988 Buick Roadmaster
Wtf do you have against learning?*clocks out*
Fight amongst yourselves.
Im guessing the head on a 78 350 wouldn’t be better than the first few years of the 350. Late 70s anything will be the early stages of smog era. Where they were really doggy.Interesting. Knowing this information, I guess my question then is what is the difference between all the gen i engines. I know I don't want to try an LS swap or TBI swap, but I am curious whether there is a difference between the 350 engine in a 1967 chevy truck vs a 1978 350 in a truck like mine? were there any performance upgrades done or are they all exactly the same year to year?
Any LT9? no..? no....i got a soft spot for the mid 70's LS9 350's the heavy duty 4 bolt main engine that is.
