Any Tricks for stuck oil filter ?
FireTruck1984
Michigan
Ted
1984 and 1984
99 out of 100 times.. I’ve been smarter than the Oil Filter, This one won’t budge. It was installed “Hand Tight” as always and with a smear of oil - but the circular clamp type wrench only crushed it. I don’t have another type oil filter wrench. Any known tricks that will work? SB 350 The Truck in on the ground (No lift) K1500 so I have plenty of access room. Thanks!
FireTruck1984
Michigan
Ted
1984 and 1984
Punch a long screwdriver through it and turn? I’ve got nothing else.
Sorry, @Copymutt beat me to it.
Thanks, I’ve used that method before. Fortunately the filter is already drained. :cheers:
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I have a rubber strap wrench that I typically try first if my hand doesn’t work. Otherwise, I have a wrench from harbor freight that has some pretty aggressive teeth. I’ve had to use the HF one on a few different Cummins. Even with the passenger side inner wheel well removed, they can be difficult.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Looks like you might git it figured or off by now but I'll throw out some ideas.
In the past ive had to use:
of course a screwdriver lol.
Serpentine belt with vice grips.
Chain wrench.
Big channelocks work good too.
Pipe wrench.
Chizzel on an old crusty one.
FireTruck1984
Michigan
Ted
1984 and 1984
I’m gonna buy these Jaws of Death
Hard
