any info on this square?
Joshua8336
Dirty South AL
Joshua
I found this square on google, and i fell in love, does anybody know how much it's lowered, what kind of rims those are, or just anything about the truck?
J Knight
Baytown TX
82 Chevy
350ci
It's an 81-87, looks to be lowered about 6/8, possibly bagged, and those might be Budnick wheels.
Yeah, it's a lot more than a 2/4 drop. I'd be willing to suggest bagged too.
Joshua8336
Dirty South AL
Joshua
out of pure luck i found an article on this truck on the reader's rides in truckin magizine, say's it's lowered 13 inches more than stock, but no exact front rear lower numbers. I'm guessing i would have to do a c notch on mine, and a 4 link, but i don't want to run bags. is there anyway i could use front and rear adjustable coil overs to get the height just like this?
J Knight
Baytown TX
82 Chevy
350ci
As far as I know if you want to run coilovers in the front you will need Mustang II front suspension and the rear you will need some type of 4 link set up. Also you will need to bridge the frame in the rear and remove the front inner fenders.
I guess lowering is like lifting. The higher the better, but the lower the better. I personally think Squares look good with a 2/4 lowering kit, and with that, you shouldn't have any real problems and it's cheap and easy compared to bagging and C notching.
Moving thread from General Discussion to Street Suspension.
Joshua8336
Dirty South AL
Joshua
where can i get a front roll pan like that?
Try lmctrucks.com
Joshua8336
Dirty South AL
Joshua
can you tell if the rear has leaf springs? it looks like it has a hanger so i don't think it has a link and c notch.
J Knight
Baytown TX
82 Chevy
350ci
If you want to lower your truck a lot on leafs you need a flip kit(5in), drop shackles and hangers(4in), remove the short and overload leafs(2in). 5+4+2=11in. To do this you will need to bridge the frame above the rear end and cut the bed floor.
Joshua8336
Dirty South AL
Joshua
I'm goin with a porterbuilt 4 link set up, but was just wondering if it was just me that thought that this truck has rear leafs.
J Knight
Baytown TX
82 Chevy
350ci
I blew up the pic and it looks to still have the leaf springs on it. The shackles are standing straight up with what looks like the leaf attached.
Joshua8336
Dirty South AL
Joshua
k thanks! i think i'm just gunna do coil overs, porterbuilt is making a coil over drop member soon, might invest in that. I've heard nothing but great things from porterbuilt.
J Knight
Baytown TX
82 Chevy
350ci
Me too, porterbuilt is supposed to be the **** to get. I'm realy liking their trailing arm kit, is like to install that for the improved ride.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
COuld what you are seeing as leaves be a rear facing link set up where the lower links facr fowards and the rear links face back. Ive seen it done before just wondering.
K5Chris
