Another electrical gremlin
MrMarty51
Eastern Montana
Martin
Allows the fuel pump on heavier duty models prime for 15-20 seconds, compaired to the 1/2 ton 2 second priming.
OHHhhh,that circuit.LOL I never heard of it call a hot fuel module is all.Thank You.
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
Me neather ... So do I disconnect that ?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
yup, just make sure the pink/ blk wire is taken care of. The ecm b orange wire is just as important as well, could be shorting somewhere. How did you find that fuse blown? you using that circuit in your conversion?
santee
cody
k 30
5.9 cummins
I have nice little fuses with light on them :) haha ! Well ok I don't need that any more correct ? It doesn't CONTROLE the sending units or anything like that ?
santee
cody
k 30
5.9 cummins
89 where did you get all those ? Is there any way you can email them to me ?
Jims86
Patterson,Ca
5.7 TBI
Nope, That would be the gauge Idle fuse. ECM 1 is all the switched power stuff on the pink/black striped wire.
santee
cody
k 30
5.9 cummins
Ok ! So I was looking today and found that this pink and black wire was connected to my sending unit . That's the fuel pump correct ! ?
I think it is supposed to be a tan and a pink and a black for a ground?
4WDKC
Southern Florida
Kacy
I know this is an old post but I am having the same problem, with the exception when i switch tanks the truck still doesn't start and the fuse doesn't blow.
mikejeden
