- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I have a edelbrock performer intake and a 1604(1406?) edelbrock carb. The fuel pump is mechanical, likely stock or replaced once in life of truck. Fuel lines are clean and replaced. Fuel tank is good. Fuel filter came with carb.
I notice that if the truck sits for a day or more, typically there is no fuel in the filter or carb, which means pumping the gas to get gas in accelerator pump would be pointless, right? Im guessing it slowly evaporates from the bowl.
In this weather, about 30 degrees, and not starting it for 3 days, I would have to pump it at least 30 times in total to get started. I wised up and realized the filter was empty and started cranking the engine a bit to fill that bad boy up first, then pump the gas which brings that down quite a bit.
My question, is the fuel filter pointing downward toward carb causing gas to go into carb then evaporate versus if It went upward, it might stay in filter for a little bit, allowing the truck to have some gas in it so it doesnt need to crank nearly as long? Or maybe weak fuel pumps? Carb? Ive never had a truly good-working carb on a vehicle before, just stock quadrajet, the old 2 barrel on this truck, and a 2 barrel on my old LTD.
