air temp sensor
Scott
Fresno
Scott
K1500
whats the difference in a air temp sensor (BWD/NIEHOFF Part # EC421) 7.00 dollars and a Thermal Air Temperature Control Valve (ACDELCO Part # 213116 ) 58.00 dollars These are on rock auto.com for a 86 chevy but a huge price difference in same catagory. Are they the same part?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
welcome To GMSB!
Your down the valley in fresno, so I assume you have the Computer controlled quadrajet. Are you looking for the bi metallic sensor in the air cleaner for the heat riser door?
Both of those sensors that you mention are the same. ACDelco is the best, but if money is tight, the bwd should get you passed smog inspection.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Someone correct me if I'm wrong but I believe the thermal valve it the big ole cast iron valve that goes on the exhaust, with the thermal spring on it. The $7 part is probably the little valve on the under side of the air can.
Scott
Fresno
Scott
K1500
thanks for replying yes the one that opens the heat riser door i was just making sure they are the same.thank you!
Jims86
Patterson,Ca
5.7 TBI
Curt, thats the Early Fuel Evap valve.
Scott, Your welcome.
Post some pics of your ride when you get a chance.
Mudbeast2
