Aftermarket tbi install
dusterdude
Marine Corps
US
mark
gmc c15
I need to buy a coil to work with the small cap hei distributor I received with my tbi kit.can someone point me to a wiring diagram for the coil I need for this?thanks
Sent from my LM-X420 using Tapatalk
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
I use a Blue Streak coil with my factory TBI. Sounds like you still have the same type of ignition system. Stock type coil should work.
Sent from my SM-A705U using Tapatalk
dusterdude
Marine Corps
US
mark
gmc c15
I agree,looking for a wiring diagram for it.any ideas?
AKguy
Alaska
Randy
K30 Crew Cab Silverado
1985 light duty
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Stock wiring ought to work. What's wrong with your 87's wiring?.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
1985 light duty
85's won't work. Coil is in the cap.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
If you are converting from a carburetor to this just follow the directions in your kit. An ignition wiring diagram for an 87-92 TBI motor would show you how the stock engines were wired.
dusterdude
Marine Corps
US
mark
gmc c15
I'm using an 87 system and unfortunately the kit doesn't have any instructions on wiring the coil.the good news is,I have an 87 gm repair manual on the way to me.thanks for the help guys.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
There are free diagrams on the forum.
dusterdude
Marine Corps
US
mark
gmc c15
Now I find out,doh
Moderator
The coil has two (interlocking) pigtails. One is just a short harness that connects to the 2-pin connector on the module. The other connector has a 12v wire and a TACH signal wire.
dusterdude
Marine Corps
US
mark
gmc c15
Bucket,thanks for the info.
dusterdude
Marine Corps
US
mark
gmc c15
crowe-t
