Aftermarket EFI? Anyone Tried It?
97350
Canada
Duane
C1500
Has anyone tried the FI systems from Edelbrock,FAST,ACCEL?Not the high tech high dollar systems but something a little more affordable.Just wondering what worked and was the best bang for your buck.I always wanted to TPI one of these trucks but by the time I buy all the TPI stuff I should be able to get into a new aftermarket system.No?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
You can put a complet TPI system together for around $500 if you are good at skimming Ebay, and digging at the wrecking yard.
As far as aftermarket, Mass-flo EFI is best IMO.
X-cabsquarebody
Western NC
Billy
C10, C10 ,K30 , 3500
305 TPI, 454, 8.1
Ran Holley Pro-jection system on a C10 and an off-road Jeep for about 10 years. Worked great. No matter what you use, take your time and install it right. Don't get in a hurry. When you cobble fuel injection systems, they will give you trouble. I currently have a TPI 305 in my truck. I get 18 mpg if I keep my foot out of it.
cooter55
Placitas, New Mexico...not really New...not really
Jack
C20, R10
454FI, 350
I've installed quite a few Tuned Port and Mini-Ram systems on various SB Chevy motors over the years. If you do your homework, you can put together an entire system for around $1000. The advantage of using the GM parts over the lower cost FI systems is that if you use the proper distributor, you can control the the timing as well as the air/fuel. My other current project is a '55 F**d F100 street rod that I put a TPI 350 in out of a '90 Corvette. The motor and complete FI system, except for a fuel pump, cost me $1000. I know friends that have installed the FAST systems and like them. I may put one on my 454 this year, but it needs a square bore manifold to do it and $'s for toys are limited.
Jims86
Patterson,Ca
5.7 TBI
The other goodthing about an OEM Efi system, is theres no chance of par un availabilty in a pinch. Some Aftermarket EFI systems have proprietary tech nology. If you Fry an ECM on an Edelbrock or Accel setup, You are stuck.
redrosec10
