Adding lower anchor points to the bed.
Ewhitaker0020
I found these several years ago, and installed them in my SOB ranch truck, but they started to rust and corrode because they were CCC. I found that Camping World has the same loops, but theirs are Stainless.
P.S. I have no business affiliation with Camping World.
I didn't see anything, if you meant to post a link or picture
Ewhitaker0020
Do you have saddle tanks? Just know your one location is directly over a driver side tank.
I checked and there's plenty of room to go between the tank and bedside. I can get my hand up in there pretty easy. I plan on going fairly close to the edge.
Ewhitaker0020
I always put eye bolts in the bed floor. One at each corner and one immediately in front of and behind the inner wheel well. Around a dollar each at any hardware store and work well.
I was gonna go with eye bolts, but I want something that won't stick up. It probably won't matter, but it's stuck in my head now.
They make those flush mounted eye mounts for trailers that recess in their own mount when not in use.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I just don’t tie anything down that’s below bed rail level. I’m the picture of safety.
As long as you don't drive around with stuff on top of the truck, and everyone having an arm out holding it, it's fine.
Ewhitaker0020
I saw those, but I think you have to drill a decent sized hole for the recessed part to sit in. That made me uncomfortable.
Vbb199
Salisbury NC
Vince
Hold it, you mean I’m NOT supposed to do it that way?
So far I've only seen Mexicans doing that with a mattress, but I guess a big dude in a brown 78 chevy holding down his firewood wouldn't surprise me too much.
Poppy 87
Bloomingdale GA
R10 Silverado
That way works great with mattresses and extension ladders
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Thought about adding anchors but I don't like to drill holes into panels if it can be avoided. Was planning on putting D-rings onto the bed mounting bolts.
Something like this.
Haven't gotten to it but it is on the someday I'll get to it list.:cool:
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I saw these today in a ranger. They look factory. Might be able to find some in a junkyard and make them work. Just an idea, I saw them in a truck at work and thought about this thread.
Green79Scottsdale
G.R. - MI
Bob
While poking around in the garage this morning I found version 2 of what was going to be front anchor points.
I don't have my truck here to show you how they were to work, but you can imagine it I'm sure. The square cutouts would go over the mounting nuts. I was going to replace the bolts with longer ones so that with the extra length I could simply use a nut and washer to hold the brackets against the front panel of the bed. I also still need to mill in the hold down slots. Clear as mud?!
Ewhitaker0020
D-rings in the bed bolts seems the best no-damage option.
I'll finally be installing the D-rings tomorrow. I sanded and primed the areas where I'll be installing the anchors to hopefully not cause any more rust than is already there. Now just need to drill 8 holes and tighten down the anchors.
wilson79
