Adding accessories to top post batteries
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
What’s the best way to do it? In the process of adding backup lights. With those, push bar lights and police scanner wiring, my side posts are getting busy. I want to move everything to the top posts and just have the truck run off the side posts. My first thought is to grab a set of battery cable ends and just bolt my accessory leads to those, but is there a cleaner, more reliable way?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
There are all kinds of bus bars/junction blocks available. Just run a single cable from the battery post to something similar to what’s pictured in a more remote/discrete location. Then run all the accessories of of it. They make all different styles. I’d recommend one with an integrated fuse block so you don’t need to run a bunch of inline fuse holders.
bigcountry78
James
K10 Custom Deluxe
Thanks for the recommendation guys. I’ll look into those. Never really thought about anything other than straight to the battery.
75gmck25
Northern Virginia
Bruce
In the junkyard I pulled a power junction block off a squarebody (the one next to the brake booster), and another 4 or 5 post power junction off a newer GMT400 truck. I mounted the squarebody junction block on the passenger side fender near the battery and use it to power the relays (and fuse) for my headlight power harness. Still looking for how to use the other junction block.
The GMT400 junctions usually have several factory wires connected that have fusible links. There are factory markings on the plastic body of the fusible link, so its easy to figure out the wire size and look up the amp capacity.
Bruce
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I used this Blue Sea System model in my truck as I only needed 4 extra circuits. 100A total or 30A max/circuit.
bigcountry78
James
K10 Custom Deluxe
I like that, looks nice and clean.
RoryH19
Rory
R10 Silverado SWB
I have this on my k5.
Ran a lead to provide power. The other 3 posts are for my LS swap power needs and accessories.
Several of my 78's factory auxiliary terminals were already in use, so I installed this Buss panel for future additions. I didn't want to overload the stock wiring. So far I only have a power port wired to it, but I may wire the original lighter socket to it as well. There will end up being a CB running off of it too, and some lights.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You can find these under hood of many late 80s-mid 90s GM cars. Cadillacs and Buick usually have them somewhere near the battery. I think they have been discontinued from GM, it would be nice if you could find them new. After 20plus years under hood, the plastic is kinda brittle.
might need to keep the posts covered so they dont get grounded?
Oh thats rare? I threw that POS away and installed a top post in my buick. Since it bolted right up.
to the OP, if you needed extra power lines a marine terminal made out of brass is nice. You could use that to run to a fuse block, so you have the ability to unhjook the whole lead
Those spade connectors are only live when they have a fuse installed. Generally if a fuse is installed, the spade connector will have a wire plugged onto it and will be protected.
The group of spades at the lower left are just ground terminals.
Camar068
Kentucky
10 yrs Air Force
I plan to install a buss panel inside the cab to help clean things up. At the battery, I've got the truck running off the top terminals, and the LS engine running off the side. I've got the side terminals running to posts similar to the ones below on the firewall.
FenderBanger
