A Technical Comedy [Only After the Fact]
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Every vehicle I have has a hidden set of keys, problem is finding them. So Kelly where you located. I am near Naches or Selah.
Turbo4whl
Downingtown, PA
Wayne
CRAP. The truck was running, I hadn't unlocked the passenger side, and I had no key for the passenger door, aside from the one in the ignition. PANIC
This here handy little gizmo works really well for wing windows: https://store.z-tool.com/products/wing-window-tool
So, every early square comes with it's own door unlocking tool. As long as the hood is not the cable release type (option on early squares) open the hood. Remove the bail wire that holds the brake master cylinder lid on. Snake the bail wire under the vent window rubber, twist it around and pull the vent window latch forward.
The bail wire works just like the tool Sad Sack posted. Newer squares take 1 second longer, you need to pull the release button in with wire tool before twisting the vent latch.
Dejure
Eastern Washington
Kelly
C15
SNORT. I used to live in Naches, back in the fifties. My parents owned Whistling Jack Lodge, but my mom couldn't deal with the seclusion the winter brought, so we moved to Naches and my dad stayed with his state highway job [eventually taking charge of the east side of the Northcross, when it opened.
Interestingly, the brochures the current owners promote don't show them as part of the history, but also shows the lodge as being built significantly later than it actually was.
Anyway, I'm an hour from Yakima, near a place called Mattawa.
We are, literally, in the middle of everywhere. We can go northwestish to Wenatchee, northish to Ephrata, North-eastish to Moses Lake, eastish to Othello, southeastish to the Tri-Cities, or westish to Yakima and it's all around an hour to those versions of civililization.
We only get to the Yakima area a time or two a year. All our shopping is done in the Tri-Cities.
Sad Sack
Nebraska
Goober
C15
Hmm. I'll have to see how that works. The heavy, high tensile wire used around here to hold up apple tree limbs just might make one.
I had my truck unlocked with one and it was super slick, even pushes in the little button, me leaving keys in truck not so slick.
hey mister
North Coast
Marty
My first thought was to just pinch the fuel line from the tank.
As for the window crank...
Just slip the edge of a shop rag in between the plastic washer/disc and the crank base. Then with just a little tension on the ends of the rag, slowly saw back and forth just as if you are using the edge of the rag to "saw" the regulator shaft off.
The rag will catch the clip and roll it right off.
Once ya get the hang of it, you can take a crank off before you can get that "tool" out of the drawer you might of put it back in.
A shop rag always goes to the bone yard with me....sometimes 2 rags...a left and right side one...lol
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Used to love that place back in the late 70s and early 80s. We’d cross Chinook to go pick cherries or buy peaches for home canning.
When our Scout troop would do PCT Chinook to White weekend “ruck marches”, would always stop at either Whistlin’ Jack or Moore’s in Ashford.
We’d run Skate Creek Rd all the time. Blueberries at Cora Lake, High Rock Lookout hikes, cutting over to go flyfishing around Cispus…
Small world. Use to race at Bremerton. Dad’s cousin raced at Yakima, lived on 410 by the bear chasing a mechanic up a tree. That cousin’s father drove off the edge of Chinook Pass in the 50s, you could still see his destroyed car glinting in the sun way down at the eastern base of the rock field… So bored living in the Memphis area. No decent hikes, no decent tracks, cruise in scene sucks…
Dejure
Eastern Washington
Kelly
C15
Narrowing the world a bit more, I moved to Bremerton around 73 to work at Puget Sound Naval Shipyard [PSNS] in Shop 51, marine electricians. From there, I went to Bangor Sub Base, then Keyport Naval Torpedo Station [NTS], now called the Naval Undersea Warfare Engineering Station [NUWES] (guess the old name was to short) electronics section.
In the end, the job was too secure and the pay to good, so I struck out on my own and now I'm here in the desert of Eastern WArshington (why work 8 hours for someone else when you can work 18 for yourself?).
If you were racing there back around that time and saw a 69 Chev step side around Bremerton or East Bremerton with etched glass windows and mahogany racks that said "Imagination Unincorporated" (Inc.?) the world was even smaller yet.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
I was hatched in ‘72… :)
Joestreml
