89S's Official Rear Tailpan Crossmember Replacement Thread
Yeah brah, you need to get that road salt out best you can. You're not likely to get it all, but you can come real close. I learned this trick a long time ago in a Popular Mechanics magazine. Best way to get the **** out, is buy your one of those rain bird water sprinklers that wave one direction sit for a second, then come back and go the other dirction and wait a second, then come back again over and over. Park your truck over the center of one of those type water sprinklers and let it run for 30 minutes or so. I prefer to put it in the front 1/3 of the truck for 15 minutes, then put in the rear 1/3 for 15 minutes, that way you're getting more pressure to more areas. But it does seem to work pretty good and what salt it doesn't get, it will at least dilute the hell out of it.
I wish the local drive in car washes had bent ends on them to be able to get up in there and blast that **** out of there.
Last night after work I got the old body bolts cut out of the floor and installed the new ones. I will be trying to put this part in today. Wish me luck.
png image hosting
Moderator Administrator
Kind of a bummer brah, but I'm seeing that your frame is really starting to bubble up with rust too. You know as those bubbles rise and flake off, the frame is getting thinner and thinner. Just saying, I'm sure you can get a few more years out of it, but I wouldn't be considering your baby a restoration project. Then again, maybe it's just the frame coating coming off and all is still good and it the frame could be blasted then POR15 in. :shrug: Good Job otherwise though and the inspector can lick your sack if he doesn't pass it. :waytogo:
I will have to stay on top of it and get under there once a year to keep the rust preventive coating going on the bad areas.
Ok, this is done! :flipthebird:
This kicked my ass, but I am very happy with the results, truck is a lot more solid now. I have to give props to Top Banana Restoration parts, this product fit perfectly, had all necessary threaded holes, even had holes for the body wiring harness clips to pop into, I was very happy with this purchase.
Took a lot of cutting and grinding, but I am over the hump, and can pic away at the small finish work as I please. I sprayed a **** load of the Rustoleum Rust Reformer all over everywhere, even the back side of the bumper.
Took me about 4 or 5 hours of actual replacement work. Doing all the prep work before hand, like getting fasteners loosened and getting the body mount bolts replaced before hand made a huge difference.
You can see in the comparison pics of the old and new parts that 75 percent of the original support channel is completely missing.
Now I am on the boat drowning my aches and pains away, lol. Enjoy the pics.
Sumbish !!! That's some major surgery there dawg. Good job !!! :waytogo:
Joeairforce
Maryville, TN
Joseph
V2500
6.2L N/A Diesel
Nice job :waytogo:
Did you put the latch for the left door back on after you took the pic?
Nice job :waytogo:
I believe that latch is in Texas right now or in the mail. :005:
I can wait though, got nickle-anit-seize on the bolts in that spot. And the right door holds them both shut in the mean time. :High 5:
nice job buddy :High 5:
Jeremy89
