- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Yeah brah, you need to get that road salt out best you can. You're not likely to get it all, but you can come real close. I learned this trick a long time ago in a Popular Mechanics magazine. Best way to get the **** out, is buy your one of those rain bird water sprinklers that wave one direction sit for a second, then come back and go the other dirction and wait a second, then come back again over and over. Park your truck over the center of one of those type water sprinklers and let it run for 30 minutes or so. I prefer to put it in the front 1/3 of the truck for 15 minutes, then put in the rear 1/3 for 15 minutes, that way you're getting more pressure to more areas. But it does seem to work pretty good and what salt it doesn't get, it will at least dilute the hell out of it.
I wish the local drive in car washes had bent ends on them to be able to get up in there and blast that **** out of there.
Last night after work I got the old body bolts cut out of the floor and installed the new ones. I will be trying to put this part in today. Wish me luck.
png image hosting
Good Job otherwise though and the inspector can lick your sack if he doesn't pass it.
