Arkansas_V8
Proud Redneck
- Jul 1, 2019
- Springdale, Arkansas
- Brent
- V20 Suburban
Who you callin yellur
Mainly all y’all’s bigger cities. Lol
I have a rolling 77 K25 frame and a rolling 78 K10 frame if you need pictures of a half ton setup vs 3/4 ton of any kind. I dont know what differences in a burban vs pickup, but very visible and intact... ish. The rear end may have separted from the 3/4 ton and tweaked the frame rails, but all the parks are there.. just strewn out a bit.something something rear end changes suburban
i think 15 doesnt clear the drums on a 14 bolt, or it would have top flush mount on the hub with no backing.. which would be a lot of pressure on a wheel.There is something I didn't think about, but a friend pointed out, I won't be able to run a 15" wheel anymore with the conversion, will I?
My county has 90,000 people and it takes an hour in either direction of center to get to the next county. I dont know what a big city is lolMainly all y’all’s bigger cities. Lol
I would be prepared to replace the metal brake lines in the rear in case you run into trouble getting them off. I know I did!
Sure did, I'll remember that if I pursue this venture.Did you see what I said about pictures
