87 350 stalling
Duckdodger
Ellabell ga
Joe
Anyone have any ideas why my 87 won't idle and shuts off when turning .
It first had this trouble about a month ago. I had a busted power steering hose so I got that fixed and changed plugs and plug wires and cap. Now the whine is back and the truck doesn't want to idle on hot or cold start ups and shuts off while turning. Could a bad power steering pump cause this I'm pretty much stumped
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Stalling under accessory load is usually the sign of a very dirty IAC valve, which is the piece on the back passenger side of the throttle body, can be identified by the square 4 wire plug. Unscrew that, and clean inside the passage, and the pintle valve, and see if that works. dont crank it more than snug when you put it back in... very easy to strip.
Disconnect the battery for 15 seconds after, then reconnect, fire her up and go for a drive to see how it acts.
mat163
CA
k15
I replaced the IAC on my Suburban, and I still have the stalling issue
Jims86
Patterson,Ca
5.7 TBI
Duckdodger
Ellabell ga
Joe
By accessory load you mean turning ?
Jims86
Patterson,Ca
5.7 TBI
Yup....also happens if the throttle blades are set too low. Power steering is the biggest drag on an engine.
Duckdodger
Ellabell ga
Joe
Pardon my ignorance but what is the thing that steering shaft
Bolts up to if I'm not mistaking its where all my power steering fluid is
Leaking to
Jims86
Patterson,Ca
5.7 TBI
steering box
Duckdodger
Ellabell ga
Joe
yeah i seem to have blown a seal, probably the seal was going bad when the hose went out and now that the hose is fixed its finished going out, instead of just replacing the seal im probably going to replace the whole box do you agree
Jims86
Patterson,Ca
5.7 TBI
Either way,the leak is fixed. Could still stall on you though.
Duckdodger
Ellabell ga
Joe
Well if it still stalls after that then ill just post us another thread to chat on. Lol
MrMarty51
Eastern Montana
Martin
It is getting tougher to find parts for the steering gear boxes,seals-OK but for shafts and such,it is getting tough.
Duckdodger
Ellabell ga
Joe
So I've heard I hope just buying an oem replacement
Solves my issue
Dons79C10
