70s to 80s cab swap
76-77-78
Garrison ND
Ethan
Ok so here’s the story. Last year I picked up an almost rust free and completely dent free pickup box for my metallic brown 77 gmc k25. The pickup the box came from is a black and grey 83 or 85 I can’t remember anymore but anyway it’s a c10. but my question is do the 80s style cabs bolt up to the 70s frames. if so are there any issues that need to be addressed. and if they don’t an explanation of why would be cool I’m always looking to learn something new. Thanks in advance
Ethan
76-77-78
Garrison ND
Ethan
Also I’ll try and get pictures tomorrow but it’s dark out at the moment
Shorty81
Baby Boomer
North West ohio
Darren
I bolted up a 86 cab and bed on a 79 chassis. The frame horns changed in 81 so I had to use a 79 front bumper. Other than that no problem.
And you have to use the correct year frame mount bushings too. That's the only 2 differences. Cab mount bushings and the front frame horns.
76-77-78
Garrison ND
Ethan
Ok are there any legal issues I should be concerned about keeping in mind I’m in ND with no smog requirements and no vehicle inspections
You would likely know your state better than most of us. Laws do vary between state. In most cases, what's most important is, that your title VIN matches the Cab VIN and the Cab VIN is not altered or been removed and reattached. Cali is one state that likes to compare the partial frame VIN to the cab VIN. OK does not compare frame VINs. They just inspect the Cab VIN to make sure it's a match to the title and no tampering has taken place and that's it.
SDJunkMan
Black Hills of South Dakota
Jeff
In South Dakota, if you combine two (or more) trucks, you are supposed to have the VIN's inspected, and show proof of ownership for the parts. I am getting ready to put a 78 cab on a 80 chassis, luckily I have titles for both, so it should not be a problem.
Is he going to have problems with the trans hump going from a 2WD to a 4WD?
You're SUPPOSED to do the same in OK too. But here they VOID the VIN's to all the vehicles and RE ISSUE a State ISSUED VIN for that vehicle and then it causes all kinds of problems when you go to get insurance and such because it doesn't come up in the Ins companies system so then they don't want to insure it so it's best to hush up and do your thang.
SDJunkMan
Jeff
I've lived here for over 30 years and never had anyone check my VIN numbers, so I am probably just going to use the cab numbers to register it. If anyone ever checks the frame, I have the title for it, so not too worried.
Exactly !!! That's what's normally done here. So long as the cab VIN doesn't look and had not been altered and matches the clean title, then we go with that. Kinda like my 86 C... uhhh I mean my 84 C20.
76-77-78
Garrison ND
Ethan
Ok to make things more complicated I would like to keep my 77 VIN because here in ND after your vehicle is 40 years old you can get special plates that is 10 dollars for the plates and you don’t have to register your vehicle every year but if that wouldn’t be possible I might just have to man up and pay the 63 dollars for a few years
SDJunkMan
Jeff
If you are talking about historical plates, most states historical plates limit how and how often the vehicle can be driven (to and from events, parades, etc.). A lot of people get away with running them but if you run into a cop thats a dick, they can cause you problems.
76-77-78
Garrison ND
Ethan
No they are special plates called pioneer plates they have no limit on mileage or anything like that they are a really sweet deal
76-77-78
Garrison ND
Ethan
Now if I could just figure out how to post up some pictures
SDJunkMan
Jeff
I've seen those Pioneer plates, that's cool that they don't put restrictions on them.
Just click on the middle button 'upload a file' on the bottom of the wndow when posting. It will ask for the location of the pic, mine always goes to my pic files. Then just click on the pics you want to upload.
macklemcole
