700r4 kicking into neutral
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
sons 87 k5 700r4 6.2
just tightened steering tilt bolts as they were quite loose. the trans was, and now worse, keeps kicking back into neutral from drive while running down the road. is this likely a column or linkage problem?
I'd look at my engine and transmission mounts,and adjust the linkage at the pinch bolt below the column under the hood.
pgreensoup
