700R4 tranny
garettjaxx
Washington
Joe
V6
My truck originally came with an inline 6 and 700R4. The tranny needs a rebuild. I'm dropping in a sb 350. Question is can I use the 700R4 that came with the i6?
1983 k10 4wd i6 700r4
oneluckypops
Sedalia, Mo.
Luke
yes you can, the stall speed on the I6 converter will likely be higher then a V8 converter would be, aswell as the 3-4 clutches, the V8's use an extra set of clutches. It would work.
garettjaxx
Washington
Joe
V6
Could it be rebuilt to the specs of one fitted behind a v8?
Inline 6 with a 700r4? Neat!
garettjaxx
Washington
Joe
V6
Yea I think the i6 is a good engine but I know for a fact the 350 is and I just happen to have one sitting here begging to go in. lol
garettjaxx
Washington
Joe
V6
yea it def came with a i6 cause the emissions info is still there under the hood.
What kind of gearing does it have?
That sound neat.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I would bore that 6 .20 over, and install a 292 crank...if it could even be done.
As pops said, yes it will work, and it will work as is. But, when the time comes to build the 700r4, be sure to get V8 clutch drum pistons. That is all you will have to change so the drums hold the extra clutch in each clutch pack. And then of course the converter as pops mentioned. That's all the difference is.
oneluckypops
Sedalia, Mo.
Luke
Pistons should be the same, the difference will be in the pressure plates. Different thicknesses for different clutch stack ups.
I won't argue that with a 700r4 since I am not 100% positive, but I am 100% positive on Th350's. On Th350, the 6cyl pistins are about an 1/8 bigger, or taller. Th350 also has different sizes of pressure plates, but they are basically for selective sizes to change clearances, not the # of cluthes in the drum. Chevy, Buick, Olds, and Pontiac also had different clearances and used different pressure plates for that reason I know,sounds strange, but its true. But, normally a piston is shorter for the v8's and taller for the V6s in most transmissions. But 700r4...:shrug:
oneluckypops
Sedalia, Mo.
Luke
aslong as you have the proper number of clutches and steels, and the gap is correct it wont matter.
Alex123
