4wd selector switch 05 silverado
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
i disconected the ground cable gona let it sit for a little bit and go try it again. maybe it needs to reset.
Drill a hole in the floor and stick a shifter on that bitch. :High 5:
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
i wish this thing had the stick in the floor instead of this electronic crap, is it possible to convert it
HRPC would probaly know. I have no idea.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Whatever servo switches your transfer case is most likely shot. I would start chasin wires with a volt meter.
In the IT world when someone has an issue a lot of times we'll just let it go for a few days and then go back to it and it'll a lot of times fix itself :lol: Go have a beer and grill some hamburgers then come back later tonight or tomorrow :D If it doesn't work then just go grab your BFH and small the crap out of your new switch :laughing1:
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
wow this is not the info i figured i would get, one guy says to cut a hole in the floor and another says to take a hammer to it if it dont work lol. thanks alot guys.
Sorry man...I think you're going down the right path disconnecting the ground and letting it "reset". If that doesn't work then I think Iman may be right with having to start chasing wires at that point.
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
well i let it set for about 30 minutes and now it showing that its in 4 low and it wont go into anything else.
:roflbow:
Somebody here has to help ya bud, I just aint' good wit that fancy pants electrical controls garbage.
You got a manual for that truck?
Can you hear it trying to engage or anything?
This is probably a stupid question on my part but I'm assuming that the tranny is in park or neutral when you're trying to use the switch?
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
yeah its in park. and no its not trying to engage when you push one of the other buttons the light just flashes for a little bit and then it goes off
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
yeah i have the maual for the truck
Shouldn't it be in neutral when ya shift?
sallyjeank10
