454 stumbles at 2500 rpm
wjvineyard865
knoxville, Tn
Wesley
New carb and float level is set halfway up sight glass but I’ve tried it at a few different places and didn’t make a difference
350 w/203
Pick-up coil? Carbon tracking inside the dist cap?
At night park somewhere dark, raise the hood and have someone rev it to 2500 rpm's. Check for arc flashes around the spark plug wires.
WebMonkey
Missouri Ozarks
my vote is an ignition problem. when the time between sparks diminishes, the problem arises.
so i'm GUESSING there is trouble in spark delivery.
had this trouble in a motorcycle. low rpm smooth running, higher rpm stumble like a 'rev limiter'.
turned out the harness from the stator was rubbed by the flywheel and dampened the 'juice' at higher rpm.
good luck!
'monkey
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Rig up a cheap vacuum/fuel pressure gauge to the fuel line ahead of the carb. Tape the gauge to the windshield so you can see it while driving. If it maintains pressure, it’s time to start looking at ignition components. If it doesn’t, inspect the fuel line. Check for kinks, rusty lines, split rubber hose, etc. if the pump is sucking more air than fuel, the engine is t going to run very well. Next, disconnect the fuel line from both the fuel pump and fuel tank, try blowing some air thru the line. Make sure it’s not clogged.
Rusty Nail
Rusty
350sbc
Running a 37-38 year old distributor by chance?
I'm at spark output voltage.
Somebody else said "pick up coil" and I bet he's ALSO right. ;)
wjvineyard865
knoxville, Tn
Wesley
Two new distributors on it so far just to make sure. I’ll rig up the vacuum guage so I can watch it while I’m driving. In gear the truck is about 15. I know it eventually gets to 0 or close at WOT but what am I watching for while just cruising?
Rusty Nail
Rusty
350sbc
Battery cables then.
Ya know one time I put a new alternator in a Honda and it ran much better.
Didja check the halogen fluid?
85K304SPD
Las Cruces, NM
Richard
Have you changed carburetor jets? The holleys are usually jetted pretty rich out of the box. What jets are in it? Did you blow the power valve with a back fire?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Most vacuum gauges also have a scale for fuel pressure. Tee the vacuum gauge into the fuel line so you can monitor fuel pressure.
Engine vacuum should stay fairly constant at steady cruise. If the vacuum drops off rapidly while the engine stumbles (at steady throttle) that’s a symptom of a restricted exhaust.
wjvineyard865
knoxville, Tn
Wesley
I haven’t changed the jets on the new one yet. I did replace power valve just to make sure. Didn’t fix it
wjvineyard865
knoxville, Tn
Wesley
Ok I taped a guage to the windshield. Got down to about 3 wot and while cruising around 50mph it was around 10. When it stumbled it dropped off for a second but jumped right back up to around 15. But the power hasn’t come back yet
wjvineyard865
knoxville, Tn
Wesley
I ordered a new alternator. I’m gonna give it a try. It’s just weird that it’s at exactly 2500 rpm that it happens every time
Are these vacuum numbers or fuel pressure? Either way, its not right.
Rusty Nail
Rusty
350sbc
An '84 @ 2500 rpm... 84.... Big block... Th400?
84.
2500 is TCC speed is the thought.
Does that activate fuel return too? Thinkin so.
One gas tank or two?
What transmission please?
need positive ID / dont guess
:hmm:
imyourhuckberry
