427 tall deck rebuild
74 Shortbed
It's ok you probably have a mouse engine in your truck..
Sent from my SM-T710 using Tapatalk
That's some funny **** there, lol, but unfortunately I do have one in the new Burb, BUT that problem will be resolved.. :D
kellerbm
US
Brandon
427 tall deck
You can use a 6.385 too and keep the pin away from the rings..
No you can't, That is only good for a standard deck height. Might work if you used the original tall deck pistons, but those aren't easy to find.. nor are they desirable.
kellerbm
US
Brandon
427 tall deck
What size rat you running in the old girl?
74 Shortbed
****, that is correct and I know better... Some days a person should not get out of bed, speak, or touch a fkn keyboard, yesterday was not a good day at all too much negative ****, sorry for the wrong info.:banghead::Stupid Me::Stupid Me:
74 Shortbed
Big Red has a big block but the new one is a half ton and came with a torqueless wonder 350, but I have a 468 from my old dually that's gonna end up in there.
kellerbm
US
Brandon
427 tall deck
You're a moron. The standard rod length is 6.135, a 6.385 rod is for a standard deck with 4.25 stroker crank. Tall deck is 10.2... standard is 9.8; when you subtract the two you get .4 that is the deck height difference. Add .4 to 6.135 you get 6.535... That is the correct rod length for a tall deck with a 4.25 stroker crank. I did the research and built one... so please by all means feel free to shut the f up and smack your face off that key board.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
What color is that block? Grey? It looks awesome. Worlds better than say... the color of that water toy leaning against the wall behind the redish/orange
floaty thing.
Dish
Big stone gap va.24219
Shane
85 blazer frame 49 truck body
400 sbc
You can build a monster motor out of a tall deck need to check out skip white performance in kingsport tn.. for your motor parts check them out prices are worth the look
redrosec10
