4.1 to 350 in a 78?
parks
fl
james
I have a 78 c10 long bed with a 250 inline six gone bad also has 3 speed with a granny gear. I want to put a 350 (has a carb)with 700r4 from a c5 vette. will the brackets for the a/c power steering pump and the engine and transmission mounts ect. fit? need any and all advice, thanks
Engine and transmission mounts should work, just need the V8 style brackets that go between the block and rubber mounts. Trans crossmember might need moved to a different set of holes. I think all the accessory brackets are different.
74 Shortbed
None of the accessory brackets will fit and the crossmember will have to be moved back some.
assa9
US
jeff
Frame mounts have to be moved up one hole so the motor mounts will fit properly. Wiring also works .
Sent from my KYOCERA-C6742 using Tapatalk
duckboy_17
