moto57
- Dec 15, 2016
- Ohio
- Matt
- 1500 k10
hey guys.
At this point ive done so much research I think my brain is going to explode, so Ive finally decided to ask some poeple that know.
Alright I'll start of with what im running.
-engine-
I have an 84 chevy 1500 with a 350 in it (atleast thats what im asumming) I was told it was bored 30 over wouldnt that make it a 355? I think my buddys just bragging up the motor he sold me.
-carb-
It has a Holley 4160 600cfm with stock jets which is 55 I believe. it has a #25 pump nozzle in it, and a vacuum secondary, which has a medium heavy spring in it, the brown one. the primary can is like an off white set in the #1 position.
The air/fuel mixture is at 1 1/2 turns out.
-distributor-
Im running a HEI vacuum advance distributor, and stock AC-Delco plugs.
I know that I have the Distributor on TDC and the plugs are in order ive check a 1000 times.
-issue-
All right down to the fun stuff.
Before I found out that the motor is suppose to be set at around 12 degrees adv. I was trying to tune the carb at TDC. and now all my plugs are soaked and black (im going to grab some tomorrow)
My question is while I was fiddling around with the carb with the motor retarded at TDC would that cause my plugs to get soaked and potentially foul out?
Is a #25 pump nozzle too big or too little possibly?
If this truly is a 355 should the timing be advanced even more?
Now that I have the motor at 12 degrees advanced it runs alot smoother but still falls on its face when you open it up quick, and still backfires through the carb and exhaust, is it safe to say plugs are roached or is the carb still set way to rich?
I also ordered some new nozzles im going to try in it too. #18 #28 and #31 nozzles.
I really appreciate the help guys.
-engine-
-carb-
-distributor-
-issue-
