35 inch tires
1986K5Wa
Washington
Walt
Okay just wondering if 35 with 20inch rims and 12.5 wide would fit under a k5 with stock suspension?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I don't think so but maybe, but for not without a **** ton of fender trimming and you have to have the right offset rims.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Under stock suspension, I highly doubt it would fit without contact of any sort no matter what the backspacing would be.
I used to run 33x12.5's on my k10 with stock suspension. It would rub on full turns and through dips/speed bumps. Stepping down to 32's gave enough clearance for no rubbing.
Size of the rim is a moot issue, but I'd consider 33x12.50 max. 35x12.50 could be done, but the least amount of tweeking and into a turn, you're going to rub without at least a 2in lift, and 4in preffered.
The88
Mhmm
South Louisiana
ThatGuy
I would dump 20s and drop to a 15
alwaysbroken
